Re: Crazy Distributor Gear Wear
If the scanner reads cam to crank position or correlation then you should be good. You want that value at 0, meaning your cam is in time with your crank. This value can be + or - 2degrees, spec for the vortec motors, meaning your cam is within + or - 2degrees, at most, of your crank. With the engine running scan this and turn your distributor a little at a time until your good. If your off a lot, like 15 to 20 degrees, then you may have the distributor installed 1 tooth off.
Pauly, good link on the timing.
1996 Chevy Tahoe LT 4x4: Built and Vortech supercharged 5.7 vortec, built Jasper Performance 4L60E, 14 bolt 6 lug 9.5 swap, Hedman headers, gutted cats, dual exhaust, Fastchip computer tune. 12mpg on a good day. SAS soon.
Proud member of the Hood-whacker Club
