Bose system with extra sub Q
I have done all my own installs up to this time.With work sending me out of town by plane I figured I could leave the truck for install while I was away so they had all the time to do it correct.
So any way,I have the bose crap and wanted to add an amp and sub as step one of bose system replacement.So I took the shop an alpine MRPM1000 its 600x1 at 4 ohms and 1000x1 at 2 ohms.I told them where to mount it and to use 4ga or larger with a breaker and not a fuse under the hood.They said no problem and I left.I pick up the truck after hours friday past and the amp seems to have very low output.The amp has hi lev inputs that they did not use.I traced the rca lines to a point at the front of the center console where they go out of sight.I pulled the radio and there are no rca lines or a hi/low adapter.So my guess is they tied into the stock sub and used a hi/low adapter.Now i did look at the gain and even with it at max the output is no better.I know the bose will cut out the bass at hi volume but with a fair amount of amp power I should at least have some good output at low volumes.Any ideas as to the problem? I know some hi/lo adapters have gains on them and that could be the problem but other than that I have no idea.Any one here have an extra sub/amp with the bose?How is it sounding?
