Old 09-12-2008, 08:40 PM   #10
TurboJugend
TurboJugend's Avatar
Re: pulling console out of bose truck
heres the most straightforward answer.
yes you can swap it out for a regular flip up style jumpseat, as the mounting brackets under the seat and bolt holes all line up and are the same.
however, you will be left with a large unsightly "hole" under your climate control where the console used to sit.
so unless you manage to take the lower piece out of a wrecked truck or something similar, i highly suggest not doing this because your interior will look like ****.
TurboJugend is offline   Reply With Quote
