Originally Posted by White_Stealth
As for the plastic piece all you need is the piece that goes from the glove box door all the way to under the climate controls. The piece that is under the steering wheel is seperate and there is no need to replace it. It is held together with multiple 7mm screws/bolts and clips along the dash.
yeah, sorry if i made it seem that way, but i meant that you only need it up to the steering wheel, its separated there and you'll see what you need
