Originally Posted by FordeatinZ71
ok, maybe i've missed this...how are you running a '78 cam in a '91 block? the '91 is a roller cam...the '78 is not...again, maybe i missed it as i just skimmed this.
are you sure it's firing on all 8? might wanna do a compression test. have you replaced the coil or ignition module yet? those can both cause weak spark and the ignition module can cause the injectors not to work right.
91 is not a roller cam.
 Matching Ninja 500r
