Old 10-28-2008, 08:13 AM   #2
KJEfting
I am THE STIG
KJEfting's Avatar
Re: Intake Gasket or Head Gasket ? Losing Coolant
Run a compression test on bank #2 to isolate whether or not it's the head gasket. If you get good results, run a coolant pressure test again and you should see it bleed down. It's either a head gasket or a manifold gasket though. Once you get the motor tore down enough to pull the manifold, it only takes an extra fifteen minutes to pull a head anyway.
1998 GMC Sierra K1500 ECSB, 120K
-5.7L, 3.73's
-K&N FIPK
-MPFI Spider Upgrade
-Doug Thorley Tri-Y Ceramic Headers
-MagnaFlow (2.5")from the headers back
-Tuned by Justin @ BlackBear Performance
KJEfting is offline   Reply With Quote
