Old 11-19-2008, 09:08 AM   #1
ChevyHoe84
Axle swap 96 Tahoe - 10 bolt to 14 bolt SF
My 10-bolt was trash, so I got me a 14-bolt SF from a 94 K1500 (or 2500..?)
I've read that I need a conversion u-joint from 1310/1330 to 1350.
The u-joint I've used before has the part # Precision 534G, and that's a 1 1/8" cap diameter, and 3 5/8" wide. (1344??)
Neither the 1310 nor the 1330 will fit the driveshaft, because they are only 1 1/16".
As for the 14-bolt, the 534G diameter is a little small, so the 1350 with 1 3/16" should do just fine..
But can anyone tell me what kind of u-joint I need?
Can't find a match..
Thanks!
ChevyHoe84 is offline   Reply With Quote
