Old 01-18-2009, 06:53 AM   #288
tonkadawg
Supporting Member
At first with the HD, I would get some bumps causing the screen to flash. I would have to hit the console where the cpu is mounted to get it to stop. I added some foam padding to both to where the case bolts to the truck and then where the HD bolts to the case. For everything except those major pot holes, it fixed the problem.
I still haven't gotten the DVD drive mounted.
tonkadawg is offline   Reply With Quote
