Old 01-18-2009, 09:17 AM   #226
created2destroy
created2destroy's Avatar
Re: NBS Big 3 upgrade
Originally Posted by Slammed94
Can anyone tell ME how to do it to my truck? I just go from Battery to block to the other ground? Thats it? And this will ground my stereo better?
There's a few ways to run a better ground. You can either run a wire directly from the battery to the frame, or to the engine and then to the body/frame. I would personally run a 4gauge(or bigger) wire from the negative terminal to one of the mounts for the alternator. Then there should be a cable running to the firewall that can be replaced with something bigger, or you can add a second cable to it.
2001 Silverado, Z71, LT, 5.3, g80, Tuned by Blackbear Performance
created2destroy is offline   Reply With Quote
