Old 02-28-2009, 01:44 PM   #1
Joe
www.HotRodSearch.com
Joe's Avatar
FS: 1967 Chevy C10 Stepside project
Time to move my project truck...
Project. Complete less motor.
Includes rebuilt 350 Turbo Transmission
Chassis is a 1972 1/2 ton 5 lug
OEM front disc brakes
Rear drum brakes
OEM dual exhaust mounting brackets
OEM Big Block mounts (1972)
Front sway bar setup
Chassis and components are Powdercoated gloss black from front to rear
Rear fuel tank is a custom built aluminum fuel ell - 16 gallons
Moog pitman and idler arms with local rebuilt power steering gear
PST Front end rebuild kit (rubber) - www.p-s-t.com
PST Trailing arm bushings (Poly)
Early Classic 4/6 drop kit - www.EarlyClassic.com
Rear end is a GM 12 Bolt, DTS built 3.73, Posi, Moser axles
Stainless Steel Brake lines & hoses from www.InlineTube.com
1 OEM hood
Doors are SOLID
Cab is partially blasted and needs the usual front and rear frame mounts replaced and some minor floor rot repaired (pictures available)
Two sets of OEM stepside short bed sides. Front panel and NEW GM tailgate in the box
I have 2 original GM 67 Front fenders, Core support and 2 GM 67-68 front grilles as well as two reproduction wheel inners.
Asking $3,900
Truck is located in Rochester Hills, Michigan 48309
Truck before tear down:
Chassis and metal:
Rear end:
Chassis:
Cab:
Joe is offline   Reply With Quote
