Old 03-02-2009, 07:42 PM   #153
cancritter
cancritter's Avatar
Originally Posted by tpulliam79
yeah I tried new computer still no luck but after the work i have been doing on my 88 something occurred to me, the return line on my 91 from the throttle body is kinked pretty good, looks like someone tried to remove the fittings and bent it pretty good, now im wondering if the restriction in the line could be causing too much gas built up and may be causing my up and down idle? what do you guys think?
as a general rule when you put in a aftermarket fuel regulator you put it in the return line....
the kink could be possible acting like a fuel regulator and starveing your engine...fix line and keep fuel lines as far away from exhaust or they will get hot and perculate giveing you same symptoms as a pluged or restricted fuel filter
[Stole/FOUND 13/03/08 :O)
91GM 4x4 excb 5.7 @ 40 over, Westers,Eld 3704.Lunati Trickflow 195 @1.6 RR,Hooker Walpro 190/overbuilt 700r4 /TCS TC,4.10/tru trac,14 bolt,Hooker LT,areofilter,Extreme TBI.msd and still adding
97/rclb/5.7/westers tune/stock
cancritter is offline   Reply With Quote
