Thread: Radio Locked
Old 03-13-2009, 04:48 PM   #45
ncoons22
Sh!t Happens.
ncoons22's Avatar
Re: Radio Locked
hey guys, had a couple pm's recently about the instructions earlier in the thread not workin, and that i had posted 'fixed so how to do it. so here's the writeup i used. looks like just the numbers posted previously in this thread were off or changed or whatever.
Originally Posted by thirdgen.org
Unlocking the Theft-Deterrent Feature After a Power Loss
If you know the code that was used to lock the radio then use the following instructions from the owner's manual to unlock the radio.
Enter your secret code as follows; pause no more than 15 seconds between steps:
1. Turn the ignition on. LOC will appear on the display.
2. Press MIN and 000 will appear on the display.
3. Press MIN again until the last two digits agree with your code.
4. Press HR until the first one or two digits agree with your code.
5. Press AM-FM after you have confirmed that the code matches your secret code. The display will show SEC, indicating the radio is now operable and secure.
If you enter the wrong code eight times, INOP will appear on the display. You will have to wait an hour with the ignition on before you can try again. When you try again, you will only have three more chances (eight tries per chance) to enter the correct code before INOP appears.
If you don't know the code that was used to lock the radio then you will have to use the dealer's unlock procedure as follows. The dealer code changes over time - the one listed is current as of this posting. If it doesn't work try 08359 or search the forum for messages with a more recent code.
1. Press and hold presets 2 & 3 for about 10 seconds until the first three digits of the display code are displayed.
2. Write the numbers down.
3. Press the AM-FM button, write down the next three numbers.
4. Call 1-800-537-5140. When asked, enter dealer code 202108, press the * button, and enter the six digit code from the radio. You will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first two numbers, press the MIN button and set the next two numbers, then press the AM-FM button. The display will show SEC, indicating the radio is now operable and secure.
To remove the code, repeat step 5. you should see --- on the radio face indicating the code is now out of the radio."
Fleet Pics Coming Soon...
ncoons22 is offline   Reply With Quote
