Thread: disc brake swap
Old 04-01-2009, 08:15 AM   #435
92chevyblue
Re: disc brake swap
I bought the King Tek brackets off ebay & pieced the other parts. The brackets bolted right on. The cadi calipers are just a shade off, they aren't mounted quite deep enough. I have everything fitted. But I haven't bolted on the rear-end yet. BTW I have a 92 2wd and swapping in a 92 4wd rear (6-lug). I used the 87-89? (don't remember the year) 4wd front rotors. Read back thru the thread for the correct year if you have a 6-lug rear. 5-lug I think you will use an impala ss rotor. Good Luck!
92 chevy 1/2 ton extended cab, 350 swapped-in edlebrock fuel injection
92chevyblue is offline   Reply With Quote
