Originally Posted by jarrodscot
i have a 1995 chevy ext cab 2 wd 2 inch drop spindles and 3 or 4 inch drop springs and a flipped rear end and notch just put it all in however my stock 15 inch wheels are getting rubbed on the outer lip of the rim and dont have full turning radius. tried trimming lower a arm to clearence it but still rub so the rims i have are the same as the ss truck wheels.
The instructions that came with your spindles should have said that they should be used only with 17" wheels or larger (or trim the end of the lower arms). You need to trim more.
I had quite a bit of material cut off the end of my lower arms, and then had some gussets welded in underneath the arm to strengthen it. (Sorry, no pix...) Don't just cut that lip off or you'll probably end up with bent a-arms.
