Old 05-16-2009, 07:36 AM   #308
jarrodscot
well unfortunatly since all my parts are reborn ( came off my brothers old bagged truck ) i didnt get all the fancy paper work or instructions. Not like i prolly would have read them. I put a 5.16th inch spacer in and barely rub the rim so i will trim just a hair more now and call it good. By the way i am guess from cruzin round last night i prolly have to notch that cross member support in center of bed seems like i am smacking my pumkin but i will crawl under today and see bout that. One note i could add to this or second it if someone else has all ready said it is that pickle forks 98% garuntee a torn rubber on a ball joint. And has any one else had the top plate holding axle in place hit the notch before. seems like there should be more clearance there?
jarrodscot is offline   Reply With Quote
