Old 06-30-2009, 09:08 PM   #8
Mark13
I'm so much cooler online
Mark13's Avatar
Re: Any body plow snow?
Originally Posted by harborfire17 View Post
Thanks for the info fella's I will probably just go with a 1 or 2 inch add a leaf if anything and maybe some 33's
Mark 13 the truck is 1987 V2500 gmc 4x4.
I'm assuming being an older truck your running a conventional mount (where just the blade comes off, lights and pump stay on the truck). Those are harder to adjust for height I'm assuming compared to the newer styles where the only think left on the truck is a mount under the front bumper. Depending on your setup your truck sitting 3-4" higher then stock shouldn't be to big of a problem. One thing you want to remember is to keep the A frame (where the angle cylinders attach and the bottom of the plow that hooks to the truck) parallel to the ground the best you can.
Thanks 454ss
98 K1500
91 Dime
03 Suzuki z400
"Where I grew up, We rode in trucks."
Mark13 is offline   Reply With Quote
