Old 07-01-2009, 05:12 PM   #2
BigChevy17
I Will ReDefine OverKill!
Re: Remove cats or keep them? chime in.. asap
imo taking them off will make the truck sound so much better
plus the price differance between a cat and two peices of pipe is pretty big
but its up to you
what muffler are you running
Originally Posted by 90Z71Stepside View Post
You should lift that truck. then you can cross over the grass between the freeway, cut across peoples lawns, drive over sidewalks, take jumps, bush honkin I will say it again bush honkin and run out of gas with the ladies out in the woods.
BigChevy17 is offline   Reply With Quote
