Old 07-01-2009, 10:40 PM   #4
BigChevy17
I Will ReDefine OverKill!
Re: 1997 Jeep Wrangler Brakes
we replaced the master cylinder and bleeded the lines and that didnt help but the brake pedal was never soft and never sank so i dont think thats it
and the brake booster is supposedly new according to the po
and when we replaced the rear shoes whoever did it before put the two big pads on the driver side drum and the two small ones on the passenger side drum
could that damage it?
i am so stumped by this
i dont know what else it could be
Originally Posted by 90Z71Stepside View Post
You should lift that truck. then you can cross over the grass between the freeway, cut across peoples lawns, drive over sidewalks, take jumps, bush honkin I will say it again bush honkin and run out of gas with the ladies out in the woods.
BigChevy17 is offline   Reply With Quote
