Old 07-02-2009, 02:39 PM   #87
VortecZ
spark plugs are for cars
VortecZ's Avatar
Re: 4BT Cummins Turbo Diesel in an 05 Silverado (with pictures!)
Originally Posted by 1LOWDIESEL View Post
i was gonna use my stock 2500 lower control arms and hubs up front to make it 8 lug.
You might want to do some measuring. I think the frame width is different between 1500 & 2500 causing a little more work? I haven't given up on that idea, I just don't have the parts in front of me to try. I hope you figure it out first!
Originally Posted by Tang763 View Post
I was wondering how the factory gauges were going to work with the new sensors, I see you managed to get through it pretty easy, do these same tricks apply to the 12v? I'm also planning on doing an SAS with 1 tons early next year.
Yes, all the same tricks apply and good luck with your build. I've got a lot of local buddies trying to talk me into doing a SAS & adding a transfer case to mine right now. I think that would be hard on my 30mpg though!
Originally Posted by Redliner Raw View Post
Any more info on the motor mount fabrication, perhaps some pics?
Very nice work here. Are you running higher boost with the turned up pump? Stock compression? High flow injectors? Also, is it the same turbo as the 5.9? My cousin has considered a 8.3 turbo on his 5.9, little more airflow, I don't know if you can do the same with the 3.9 to 5.9.
I don't have many good pics of the mounts. The process of fabbing my mounts was no different than fabbing any type of mount. You just start by welding plates to the frame so the hydraulic mounts have a place to sit, then bolt plates to the motor and start welding to them to connect to the mounts. The motor was hanging from a hoist and and positioned where I wanted it while I was making the mounts.
Currently, my motor is 100% stock with the exception of the fuel pump being turned up. The turbo is an HC1 wich is the same used on the first generation 5.9s. I do have plans to upgrade it but haven't decided on what exactly I'm going to do. (one bigger one on top of this one or one bigger one instead of this one)
Originally Posted by LonLB View Post
One vote for pump cranked to the max, o-ringed head, 70lbs of boost, and mini-tub....
Given the numbers the 6cyl cum ons get I would think that thing should be able to hit 500hp, 1000lb/ft with a bit of work.
Did they make an ISB version of the 4BT? I've heard that the 12V pumps on a 24V ISB can crank some serious HP, like 800HP, 1200 lb/ft easy hands down, with some other mods of course.
Originally Posted by Black06 View Post
best bet is to just do the p pump conversion and intercooler. Although easier said than done since the 4 cylinder p7100s are harder to find
I have heard of guys getting over 800hp with these little motors but that will take more money than I am willing to spend right now. I really wanted a p-pumped motor to begin with but they are a lot harder to find and usually draw more money. They did make a 16 valve version and bumped the cubes to 4.5. We have one in a Case skid steer right now but I haven't heard much of anyone putting them in trucks.
Daily - 2005 2wd Silverado with a Cummins 4BT & NV4500
Farm - 1995 4x4 Dodge Ram with a Cummins 6BT & NV4500
Toy - 1991 Camaro with full air ride, a built Vortec 350, & T56
MY PICTURES
VortecZ is offline   Reply With Quote
