Thread: disc brake swap
Old 07-02-2009, 07:41 PM   #438
Heslekrants
Heslekrants's Avatar
Re: disc brake swap
Originally Posted by hoggy View Post
So i have been tryin to read all of this but i have not seen anything that answers all of my questions. I have a 6 lug 14bolt that i am installing in my 1990 1/2 ton. also have a set of extra front calipers, pads and rotors from my 90. can i use the backing plate off of the rear of an 02 or 03 model 10 bolt to mount the calipers? or is the kore3 large enough to mount my calipers. i read that it mounts gm small calipers, not sure if this is considered small or not.
Your 90 front calipers will not work with the backing plates from an 02-03 10 bolt rear disc. The calipers are way different.
The factory 10 bolt rear disc setup comes in 2 flavors.
1) Single piston caliper & 12.8" rotor.
2) Dual piston caliper & 13" rotor.
1999 K1500-Int balanced 383, 10:1 pistons,534 lift cam,6"rods,alum heads,1.6RR,welded alum vc,LT4 knock module,MPFI conv,HD built tranny,custom ECM,headers,Flowmaster SUV50,highflow cats,drilled/slotted rotors,HID headlight,LED running lights,305-50-20 tires.14Bolt SF 4.10 gears & 13"rear disc
Heslekrants is offline   Reply With Quote
