Thread: disc brake swap
Old 07-03-2009, 01:54 PM   #441
Heslekrants
Heslekrants's Avatar
Re: disc brake swap
Originally Posted by BRAPP View Post
thanks. and the backing plate from the 10 bolt will be a direct bolt onto the 14 bolt i have?
It bolts up but you need a 60mm spacer(s) between the 14 bolt axle flange & the 10 bolt backing plate to get the caliper & rotor to align properly.
Here's a conversion kit that uses rotors, calipers, pads, front brake lines (optional) and banjo bolts for an 85 Chevy 1/2 ton pickup 6 lug FRONT axle. If you want to keep your e-brake simply use '78 El Dorado rear calipers instead of the Chevy front calipers.
This is the same place that made my 60mm alum spacers.
http://cgi.ebay.com/ebaymotors/14-Bo...A1%7C72%3A1171
1999 K1500-Int balanced 383, 10:1 pistons,534 lift cam,6"rods,alum heads,1.6RR,welded alum vc,LT4 knock module,MPFI conv,HD built tranny,custom ECM,headers,Flowmaster SUV50,highflow cats,drilled/slotted rotors,HID headlight,LED running lights,305-50-20 tires.14Bolt SF 4.10 gears & 13"rear disc
Heslekrants is offline   Reply With Quote
