Old 07-04-2009, 06:45 AM   #15
xsbchevy
xsbchevy's Avatar
Re: Remove cats or keep them? chime in.. asap
the cat has a lot to do with it. if its backed up the rear o2 wont read properly. o2's have control over the lean/rich mix. if it says ok im getting to much fuel i need to trun back the mix and vice versa. the way the dealer mech explained it is the passenger side was fighting over fuel mixture and threw the pump for a loop. it didnt kill it totally but it screwed up the fuel pressure. when mine went bad i would top out at 50 then slowly drop to about 10. id kill it set for 5 min and do the same thing again. i was getting about 10-15 miles before it started doing it again
they just dont get it do they......
Its a V-6 thang
xsbchevy is offline   Reply With Quote
