Originally Posted by xsbchevy
i did some searching after i posted the last one your right. but if i had all 3 injectors on one side going full it could cause fuel pump problems wouldnt it. like i posted the guy at the dealership explained it to me that way. so i assumed he knew what he was talking about.
the first problem is you assumed he knew what he was talking about. just cause they are at the dealer, by no means they know what they are talking about.
but the pump will pump at a constant rate, so whether at an idle or at WOT your pump is pumping the same so it does not matter if one cat is clogged or not.
