Re: disc brake swap
My local U-Pull-It only charges me $28 for the 10 bolt rear disc calipers & backing plates. I've bought 4 rear disc sets so far. I only live about 3 miles away so I visit the yard often.
This is the 14 bolt for my 99 Burb. I used the rear brakes from a 2000 Burb 10 bolt + a 60mm spacer.
If you want rear disc on a 5 lug rear the 77-78 Caddy DeVille rear disc are a direct swap for a fullsize 5 lug truck 5x5 bolt pattern. Just use the 79 Firebird rear rotors to get the 5x4 3/4 bolt pattern which is what we did on my Son's 74 Camaro.
1999 K1500-Int balanced 383, 10:1 pistons,534 lift cam,6"rods,alum heads,1.6RR,welded alum vc,LT4 knock module,MPFI conv,HD built tranny,custom ECM,headers,Flowmaster SUV50,highflow cats,drilled/slotted rotors,HID headlight,LED running lights,305-50-20 tires.14Bolt SF 4.10 gears & 13"rear disc
