I know you have already cleaned the IAC, but did you just spay it or did you clean it off and swab out the passage. I sprayed mine out twice searching for the fix for a bad idle. Finally pulled it out and wiped off the IAC pintle gently until it was spotless and then used q-tips and carb cleaner to clean the IAC passage until the swabs cam out clean and the passage was clean.
