Old 01-06-2003, 09:56 PM   #1
97Silverado
Premium Member #5
Original Gold Member
97Silverado's Avatar
Member ID: 347
How an alternator works!
Here is a good explanation of how an alternator works:
Alternator Construction and Operation
  • An alternator or A.C. generator creates voltage by rotating a magnetic field inside a looped conductor.
Alternator Components
Rotor
  • A multi-pole electromagnet that is rotated by a belt & pulley.
  • Usually 4 to 7 pole pairs.
Rotor Components
  • Winding & Slip Rings
  • Magnetic Pole Pieces
  • Shaft With Iron Core
Stator
  • A circular laminated iron frame that holds the looped conductor.
  • An automotive alternator stator usually has three separate looped conductors.
  • Each conductor has as many loops as the rotor has pole pairs.
  • The current output is 3-phase (3 over-lapping A.C. currents).
Stator Winding Types
  • Wye (Y) - 3 looped conductors connected in series. Higher voltage output at low speeds.
  • Delta - 3 looped conductors connected in parallel. Higher current output at low speeds.
Rectifier Bridge
  • A set of 6 or more diodes used to rectify the A.C. current in the stator into D.C. current before it leaves the alternator.
  • The diodes are mounted in a heat sink.
The Charging System consists of two circuits: Output and Field
-Output Circuit:
  • The output circuit consists of the stator windings, rectifier bridge, battery and all electrical loads.
  • The stator produces current in two conductors during the same time period.
  • As the rotor rotates, the stator windings that produces current change every 120 degrees. This produces 3-phase output.
  • As the magnetic poles alternate past the loops they produce A.C. voltage.
  • The rectifier bridge consists of positive diodes connected to (B+) and negative diodes connected to (B-) in pairs.
  • The stator output goes into the bridge as A.C. and leaves as D.C.
-Field Circuit:
  • The field circuit may consist of the rotor winding, slip rings & brushes, voltage regulator, indicator bulb and wiring.
  • The field circuit controls the current flow through the rotor winding.
  • This current is called the “excitation” current.
  • Excitation current is provided by the battery before the stator begins producing current.
  • The stator provides excitation current after the alternator starts producing current.
Voltage Regulator
  • The voltage regulator is part of the field circuit.
  • It limits alternator output voltage by controlling the strength of the rotor field.
  • The regulator senses battery voltage and controls system voltage to a safe level by pulsing the rotor current.
  • Long pulses result in a stronger field and higher voltage output and vice versa.
  • Maximum alternator current output is limited by stator CEMF.
  • Output voltage will exceed 16V if not regulated.
Field Circuit Types:
-“A”
  • The regulator supplies the ground for the field circuit. The other side of the field is connected directly to battery B(+).
  • Both brushes are insulated.
  • “A” for after rotor!
-“B”
  • The regulator supplies B(+) for the field circuit.
  • One brush is insulated, the other is grounded.
  • “B” for before rotor!
-Isolated
  • The ignition switch supplies B(+) to the field.
  • The regulator supplies the ground. Both brushes are insulated.
_________________________________
Alternator Output
  • Measure current output at the alternator B(+) wire while loaded to 12V at 2000rpm.
  • Should be within 10% of rated output.
  • Example: Alternator rating; 120 amps Tested output should be 0.9 x 120 amps = 108 amps minimum
