Old 04-15-2003, 11:02 AM   #6
DirtySouthZ71
Always Broke
DirtySouthZ71's Avatar
Member ID: 2366
Just curious, are Super duty front springs longer than the 73-87 GM's? If so are they too much to fit properly.
I do not know the lengh of the Superduty's spring (I think shorter)but what really matters it the length to the center pen. In order to use superduty springs you are going to have to use their style of brackets also. In order to center the axle in the wheel well you will place the rear tension mount (which I do not like because of its through the frame design) very close to the wheel well under the front clips bodymount.
I know the trend in newer trucks is to run longer wider leaf springs with less leaves in the pack to improve ride quality.
Mine rides like a John Deere..... Honestly if you don't go custom springs the best ride on leafs Is going to come from Skyjacker.
~SkankFab Off-road~
00' F-350 PSD CC 14" on 44's
89' GMC K-1500 D60/14ff 12" on 40's
85 Toyota (Tons of parts to install I just have no time)
