Old 04-15-2003, 02:41 PM   #8
DirtySouthZ71
Always Broke
DirtySouthZ71's Avatar
Member ID: 2366
Originally posted by Luke2kZ71
i assume u can use any axle as long as u have the right pirches right? like if i had a dana80 rear and a dana70 front.... as long as the pirches mached up, they are usable.... on the new trucks
what kind of errors would u get ... as far as abs lights, 4wd lights, ect...
Yes you can use almost any axle you wish as long as the transfer case is on the correct side. As for spring perchs they can always be moved. You ditch the autotrac case and run without ABS. Few people tried to use the Autotrac (Tjandlisa a former member here) did but it burn up shortly after.
~SkankFab Off-road~
00' F-350 PSD CC 14" on 44's
89' GMC K-1500 D60/14ff 12" on 40's
85 Toyota (Tons of parts to install I just have no time)
