Old 05-27-2003, 10:19 PM   #12
gmcsid
GMC Tech
gmcsid's Avatar
Member ID: 4484
Originally posted by TireFryer30th
I am also having problems with my A/C...it takes a long time for it to get cold, and sometimes it barely gets cold.
TireFryer
I have seen a lot of cycling switches malfunction. It's located on the accumulator, (long cylinder at passenger side firewall). When the a/c is blowing warm, see if the compressor clutch is engaged. If not, tap on and wiggle the connector of the switch and see if the clutch engages.
There is also a bulletin (#02-01-38-007) It explains some additional a/c performance checks for the tech to do for a poor a/c performance complaint.
SUBMAN, there are no a/c recalls for the 03 XL. There is a bulletin for poor a/c performance at idle or in traffic. (#01-01-39-004A ) The fix is to install an auxiliary electric fan.
If anyone want's to check your vehicle for recalls you can post or PM me your VIN and I can check for open recalls and warranty history.
