Old 11-24-2003, 03:31 AM   #27
Stroker 1500
formerly rcfast
Member ID: 4488
Originally posted by 97Chebbie
PS: sux when you end up having to calculate labor into a lot of installs, but it beats screwing something up and only cussing myself out.
Thats always what makes the install fun...on another note though, after my experiences with people installing stuff for me or doing stuff it makes me hard to trust people (work was done on other vehicles) no one touches my truck now... One experience i had was with my an old truck that i got a system installed in...the guy that installed it put deck screws all the way through the cab wall and almost put the same screws through the bed (this was to hold the amp) another experience i had was with my current truck..i had someone lower it (only because i didn't have a torch and welder) and they installed the centershaft support upside down which caused about a inch of play in the driveline..they also didn't cut enough out of the a-arm on one side so it rubbed when i made turns and jacked my rims up...and the last thing they did was not tightning the crown nut tight enough on the wheel bearing so it cause tons of play in the wheel...all theses problems where caused by them and i ended up fixing all of the problems myself
98 silverado....Built 383
Trying to do thing's a l31 "could never do"
