It is not guaranteed to chip off and it depends on the areas you do. If you prep it right and get a good bond then a lot of times you dont have a ton of problem with chipping, but you will notice over time that any high traffic areas will start to wear and fade. I know this from experience because 2 of the vehicles I sponsor have done this and it turned out great, but they are both daily drivers and the areas where seats slide back and forth or where you have any type of rubbing you will get wear and so forth. Not saying is not a viable option because it works and can look great and last a while, but it is not as permanent as the method I described. It always depends on what you want the final product to look like too.
Jeremy
