Thread: LED inserts
Old 02-19-2004, 05:23 AM   #62
GMSMALLBLOCKGUY
Time Kill Specialist
GMSMALLBLOCKGUY's Avatar
Member ID: 8100
Originally posted by 46and2aheadofme
anyone figure out that cutaway pic yet?
looks like the very outside shorter strip is the reverse light, does it have white plastic over it?
the middle strip is the running light?
the big bank on the right lights up along with the middle strip when braking?
how are you going to do the backup lights, gmsmallblock?
I plan on using 25 8,000 mcd 20 degree ultra white leds in a group for each reverse light.
Looking deeper into the caddie lights(Thanks for the pics guys) I think I will work on keeping the reflector in with LEDs behind. I am also not going to use the overdriven super bright leds they used rather I will use about 2-3 times as many 6,000-10,000 mcd leds.
Maily because the cost of the heatsink and the super bright leds would put each tail light up close to $500 and reduce the life of each led greatly.
make it better for less with your local junkyard
"I found JESUS!, If unclaimed for 30 days he's mine for good."
