Old 04-20-2006, 01:02 PM   #21
LiLHooT's Avatar
Re: NBS Big 3 upgrade
2 Questions:
1 Do you have a pic of where on the block you tapped your Ground? I tried following the factory ground and
2. Instead of making the run from the alt to batt, could you not just remove that fusable link of 12ga wire in your 2nd picture and go into that distro block? There is a nice chunk of metal inside that red housing with some nice lugs to tap into. The reason I ask, I still have the factory batt and side post real estate is at a premium, if you know what I mean.
05 Crew Z71
70 fleet side
When it quits being fun...quit doing it
LiLHooT is offline
Old 04-20-2006, 03:28 PM   #22
eBay-aholic
x6369x's Avatar
Look right above the power steering cap:
That goes to the factory ground on the firewall:
x6369x is offline
Old 04-20-2006, 04:18 PM   #23
LiLHooT's Avatar
GOTCHA! I see now What about question 2?
05 Crew Z71
70 fleet side
LiLHooT is offline
Old 04-20-2006, 05:50 PM   #24
eBay-aholic
x6369x's Avatar
NO, if you replace the fusible link, the weakest link is now the piece of OEM 6 gauge wire from that red distro block to the battery.
x6369x is offline
Old 04-21-2006, 11:22 AM   #25
does anyone know where the block ground is on an OBS?
OoMesKoO is offline
Old 04-21-2006, 11:33 AM   #26
LiLHooT's Avatar
Ok maybe I don't understand the purpose of the fusable link. Electrically the fusable link and + of the batt are the same point. If you make the run from the alt to the batt...you eliminate that fusable link.
05 Crew Z71
70 fleet side
LiLHooT is offline
Old 04-21-2006, 12:12 PM   #27
Washed out of Louisiana
94FlamdS10Blazr's Avatar
yes and you eliminate a huge safety feature that might save your truck from burning to the ground one day
04 EC Silverado 4.8L,Pioneer, Rockford Fosgate, K&N, Viper, ACT, USSpeedo, Matrix, Whelen, Blackbear, 22" Eagles, Nittos,Russel,Magnaflow
94 4 Door Blazer, Pioneer, Rockford Fosgate, Suicidedoors, Eagle, Nitto, PCM4Less, Vortech, Hedman, K&N, Granetelli, Bondo(lots), way deep under construction
94FlamdS10Blazr is offline
Old 04-21-2006, 12:14 PM   #28
one on the back drivers side of the head going to the fire wall, maybe another on the alt bracket, cant remember
Old 04-21-2006, 12:19 PM   #29
Raw-Edged Aggression
Bigdrumma22's Avatar
Question Re: NBS Big 3 upgrade
Originally Posted by 94FlamdS10Blazr
mine used to go as low as 11.5 hitting, now maybe 12.8. I also added about 1.5 miles to each gallon on the highway
You really gained 1.5 mpg??? That's crazy! If it can do that, I'll definitely do it.
1984 K10 Scottsdale, 350/TH350, Edelbrock AVS O/R 4Bbl, K&N, Flowtech Ceramic LT's, Dual 2 1/4" exhaust, Dynomax Super Turbos, MSD 6AL, Accel Billet Distributor, Optima Red, 31X10.50 BFG A/T's, PIONEER DEH-P5800MP, GM-X362 & TS-C1353 comps, GM-D510M & 2 TS-SW124D's, and more to come
Bigdrumma22 is offline
Old 04-21-2006, 12:26 PM   #30
I sure did on the highway
Old 04-21-2006, 01:11 PM   #31
LiLHooT's Avatar
Ok, so you are saying "Don't" do this mod. Just do the grounds
I believe the point of this is to increase current flow from ground back to alt (I studied hole flow). By jumping the link from the alt to the batt...you ellimnate the fusable link to the red junction box.
My question is, if you are going to do this, why not just run an 8" piece from the alt to the red junction box...
It was stated earlier that if you did that the minimum ga wire would be 6Ga. But if you run this direct to the battery as stated, you eliminate everything. You have 1/0 ga direct wired to the alt. Oh well...
05 Crew Z71
70 fleet side
LiLHooT is offline
Old 04-21-2006, 01:13 PM   #32
fknlow
cajundragger's Avatar
no this mod just improves voltage flow all over. If your a puss* and worry about the fused link put a fuse on the alt to batt wire...
2000 ECSB, 5.3, magna flow cat back, some beat in the back and a killer front stage
cajundragger is offline
Old 04-21-2006, 01:30 PM   #33
LiLHooT's Avatar
Thanks skipper for you well thought out response and for answering the question. Way to contribute!
05 Crew Z71
70 fleet side
LiLHooT is offline
Old 04-21-2006, 01:32 PM   #34
fknlow
Im just tired of people giving information they have no clue about. You will have no problems running a straight wire from your alt to your batt with no fuse...so I don't know why people continue to say you will have a huge safety hazard...my post wasn't directed at you at all, but someone else in this thread.
Old 04-21-2006, 01:47 PM   #35
LiLHooT's Avatar
My bad on the comment. I just don't have the room on my side terminal for another wire. So I would just jump from the alt to the red distro box (still don't get that thing). Which after thinking about it, is easier. I was just wandering why that wansn't done in the demo here, unless the wire into the disto block is <1/0 Ga. If that is the case, then I understand. But electrically, they are the same. You have to understand, I don't like "just do it"...I like to hear the theory behind it...
05 Crew Z71
70 fleet side
LiLHooT is offline
Old 04-21-2006, 01:52 PM   #36
fknlow
by going straight to the battery your helping flow that much more...your amp is hooked directly to your battery right? Just like why wouldn't you hook your amp up to the fuse block? Because voltage flow isn't as good there...go straight to the battery, heres how..use one of these available at napa...http://www.darvex.com/miva/merchant....t_Code=SGMBATT
just go to napa and tell them you need a gm battery terminal with the extra screw in the end...
Old 04-24-2006, 08:59 PM   #37
Post Whore
Faze2183's Avatar
ok i just tryed todo the big 3 and i dunno if i did something wrong? but when i turned the truck on it ideled all goofy. i thought maybe it just needed to kinda recharge a bit then i gave it some gas and it did shoot the rpms up but once it came down it killed the truck... did i do something wrong or???
Faze2183 is offline
Old 04-24-2006, 09:45 PM   #38
eBay-aholic
x6369x's Avatar
What exactly did you do?
x6369x is offline
Old 04-25-2006, 04:09 PM   #39
They also have these at pepboys for like $3 as well
fox_forma is offline
Old 05-12-2006, 04:55 PM   #40
Thank God Ima Country Boy
Z71IN''s Avatar
At what point is this upgrade necessary?? What kind of systems are you guys running?
2004 Chevy Silverado Z71 - came stock with huge payment
Flowmaster & Wester's 89/93 Dual Tuned
Z71IN' is offline
