Old 07-24-2006, 01:15 PM   #61
96Burbo
96Burbo's Avatar
Member ID: 44335
Re: NBS Big 3 upgrade
Originally Posted by 94FlamdS10Blazr
Im sure it would be cheaper and easier to just buy some bulk wire and a few connectors and do it yourself, screw a $35 kit
I hear ya, but time is an issue for me. It's usually easier for me to just pay more cuzz there isn't enuff time in the day for me.
I'm a bit confused though, It looks as the the pictures show black wires connected to the amp, and there's no mention of it..
Lastly, I'm confused a bout a adding a fuse or not? and where?
96 K1500 Chevy Suburban 5.7L
  • 350 stroked to 383
  • Volant CAI
  • Wait4Me Tune
  • Flowmaster 40 Series w/Magnaflow tip
  • JVC KD-SHX750 Deck
  • 2 Alphasonik PSW812J 12's
  • 4 Alphasonik PCT6501 6.5" Components
  • 2 Alphasonik PFZ410 4x10's
  • Alphasonik PMA1000DA Amp
Old 07-27-2006, 07:24 PM   #62
x6369x
eBay-aholic
x6369x's Avatar
Member ID: 815
replace the wire with the newer bigger stuff
I've always added to the existing wire, never replaced. If I ever sell my truck, I can undo the BIG 3 and everything is still stock.
Old 08-02-2006, 01:44 PM   #63
ltn
Member ID: 40455
does anyone know the exact part numbers and lengths for everything i would need if i just wanted to get some black welding wire. ie wire, guage, connectors. I also have a regular side connector battery without the top connectors, so im assuming i can get those things from like autozone that go into the side connectors.
Is the Juice worth the Squeeze...
Old 08-02-2006, 03:35 PM   #64
87vertgt
87vertgt's Avatar
Member ID: 51553
I dont think anyone has part numberrs. You need to go to a audio shop and start buying foots of wire and connectors.
Autozone most of the time doenst care this stuff.
I purchased everything online on ebay...much much cheaper.
I got a foot of zero gauge stinger wire for $1.99 compared to $6.00 at a sound shop
1995 2 Door Tahoe-Lade 5.7 350 TBI, K/N Intake, CFM bored TB, Helix spacer, Hooker full length header, Magnaflow muffler, Magnaflow high flow cat, Ebay chip (didnt do s h i t) Msd coil, Msd Wires, Pullys, Big 3 Upgrade, 250 amp alternator....looking for more bolt on's
Old 08-02-2006, 10:59 PM   #65
ltn
Member ID: 40455
Ok now what is that thing that i need if i have a side connector batter with no top one and can i get those at like autozone. Also all off the grounds, do they have old ones of where they used to be and if so do i just use the same grounds for the new wires.
Old 08-03-2006, 10:46 AM   #66
x6369x
eBay-aholic
x6369x's Avatar
Member ID: 815
Originally Posted by x6369x
Yes, you just need to replace the OEM battery terminal lugs with GM adapters like this from Stinger:
You just need to add a ground from the block to the firewall (if there is an existing one), and add another ground from the battery to the chassis.
Old 08-03-2006, 11:22 AM   #67
ltn
Member ID: 40455
So the ground from the battery to the chasis is the negative side to somewhere underneath the battery or what. Also where would be the best place to do the engine block, i saw where the ground was on the firewall but im kinda oblivious on where to put it on the block and the one for the chasis. thanks.
Old 08-03-2006, 02:34 PM   #68
x6369x
eBay-aholic
x6369x's Avatar
Member ID: 815
Yes, just make sure to scrape away the paint on the chassis.
What year truck/SUV? It can pretty much go to any bolt on the block.
Old 08-03-2006, 04:02 PM   #69
jm30349
MilkShake
jm30349's Avatar
Member ID: 1001
Originally Posted by cajundragger
no this mod just improves voltage flow all over. If your a puss* and worry about the fused link put a fuse on the alt to batt wire...
Call me what you want, but that fusable link has infact saved my truck from burning to the ground due to a short inside the cab. It was bad enough with the wires under the dash melted, but I can only image having the truck completely on fire with no fusable link.
Oh well, what are you gonna do?
Old 08-03-2006, 04:04 PM   #70
Bagged 04
Pssst! What's that noise?
Bagged 04's Avatar
Member ID: 35528
So let me get this straight:
You did alt to battery positive (i have done currently)
Did you do battery to engine block or firewall? Or batter and engine block to firewall? I've been wondering this part so I could get the grounds finished on my truck.
Also do you have factory exhaust manifold? On my 04 GMC I have headers and been wondering if it would get to hot for a wire that close to them.
Thanks for any info.
Sig by GMracer
Originally Posted by lowryder99
If Jesus built a two linked truck then guess what...Jesus did it wrong too!
Old 08-03-2006, 04:26 PM   #71
ltn
Member ID: 40455
x6369x I have an 02 avalanche if that helps and you could tell me where i could put the grounds and stuff.
Old 08-03-2006, 05:16 PM   #72
ltn
Member ID: 40455
would this help with the amp draw that happens at idle with the 05 fans when the a/c kicks on with the fans?
Old 08-03-2006, 11:28 PM   #73
x6369x
eBay-aholic
x6369x's Avatar
Member ID: 815
I'm not sure what the engine compartment of an Avy looks like, but my pics are from my 02 1500HD with the 6.0 motor.
Look at pic #2 of page 1 of this thread. The ground goes from the bolt right above the power steering "dip stick" to the firewall ground in pic #3.
The battery ground goes straight down towards the ground and is grounded to a frame bolt near the left front fog light (sorry I don't have pics of it).
Old 08-03-2006, 11:36 PM   #74
ltn
Member ID: 40455
ok cool thanks for the help, however do u know how big the bolts are because im thinking about using these. http://cgi.ebay.com/Sound-Quest-By-S...QQcmdZViewItem
Also should i just get the 0 gauge wire or would 4 gauge be enough for like a 145 amp alt? thanks
Old 08-03-2006, 11:53 PM   #75
ltn
Member ID: 40455
also where is the cheapest place to get some heat shrink wrap/tubing. thanks
Old 08-04-2006, 12:14 AM   #76
x6369x
eBay-aholic
x6369x's Avatar
Member ID: 815
I used something like that and had to drill out the hole a bit. It's only a few $ more for 0 ga.
Old 08-04-2006, 12:40 AM   #77
ltn
Member ID: 40455
ok cool ill just do that then but where can i get shrink wrap i have no idea on where to get it from, do they sell it like at home depot.
Old 08-04-2006, 10:09 AM   #78
ccreddell
FSC CHAPLAIN
ccreddell's Avatar
Member ID: 42598
Yes, and Radio Shack, and just about any hardware store.
I'm allergic to stupidity. If exposed, I may begin to insult the cause repeatedly.
'93 Chevy 4.3/5-spd 17" Eagles
'00 Yukon XL
Looking for a complete 3.73 posi 5-lug rear end
Credit for sig goes to Chuggernaut-Thanks!
Old 08-04-2006, 11:25 AM   #79
ltn
Member ID: 40455
now when we do the engine block to ground, does it have to be the fire wall or is that because it is close. Also I have found this out, is this a good place to put te engine block ground?
http://www.gmfullsize.com/forum/showthread.php?t=61229
about half way down the page for the pics. let me know thanks.
Old 08-05-2006, 11:32 AM   #80
x6369x
eBay-aholic
x6369x's Avatar
Member ID: 815
That works too. I just added to the existing ground that went from somewhere on the block to the firewall.
