Old 08-05-2006, 03:03 PM   #81
ltn
Re: NBS Big 3 upgrade
Ok i know it sounds stupid and it probably is but y do u need to ground the block?
Is the Juice worth the Squeeze...
ltn is offline
Old 08-05-2006, 03:04 PM   #82
eBay-aholic
x6369x's Avatar
Because the alternator is connected to the block, and you want to make sure it has the best ground possible.
x6369x is offline
Old 08-05-2006, 09:59 PM   #83
ltn
Hey 6369, what type of alt do u have? Also do u have and electric fans?
O yeah does anyone else have the 05 efans and have the noticed it help with the amp draw when both fans come on high.
ltn is offline
Old 08-05-2006, 11:06 PM   #84
eBay-aholic
x6369x's Avatar
Stock alt.
x6369x is offline
Old 08-06-2006, 04:29 PM   #85
MilkShake
jm30349's Avatar
I am a little lost. The power wire on my 92 RCSB goes from the battery to the starter, not the alternator. What is the proceedure for this? Do I just upgrade that wire instead?
Oh well, what are you gonna do?
jm30349 is offline
Old 08-07-2006, 03:45 PM   #86
eBay-aholic
x6369x's Avatar
Follow the wire from the ALT and see where it goes.
x6369x is offline
Old 08-07-2006, 06:00 PM   #87
MilkShake
jm30349's Avatar
From my alt it goes to a wiring harness, thru a fusable link (I believe that's what it is), and over to the junction box on the firewall. From there it goes out to the battery.
Good deal. I have enough 4 gage to make both runs along with the ground side. I also have several set screw terminals as well and an inline fuse block. I should be good.
Thanks for the info.
jm30349 is offline
Old 08-07-2006, 06:51 PM   #88
eBay-aholic
x6369x's Avatar
Just add a piece of 4 GA from the battery to the alternator, and leave the stock wiring alone.
x6369x is offline
Old 08-07-2006, 06:57 PM   #89
MilkShake
jm30349's Avatar
Due to the fact that the truck has almost burnt to the ground before, I am going to at least run a inline fuse for it. Thats if I don't go thru the junction box.
jm30349 is offline
Old 08-10-2006, 10:52 PM   #90
Lspade's Avatar
Why do you go from the block to the chassis? Can't you go from the block strait to the neg term on the battery? So the big 3 would be like this:
Positive to Alternator
Block to Negative
Negative to Body
Lspade is offline
Old 08-11-2006, 03:19 AM   #91
eBay-aholic
x6369x's Avatar
Block to Negative
Negative to Body
You could do it that way I guess, but the purpose of the Big 3 is to upgrade the OEM wires that go from:
alt to pos,
block to chassis/body,
neg to chassis/body
x6369x is offline
Old 08-11-2006, 09:51 AM   #92
Lspade's Avatar
Ohya, haha, I guess that makes sense. Im gonna get started on it then, thanx.
HU - Eclipse CD3000
Speaker Amp - Infinity
Front Stage - 5.25 Kicker Titanium
Subwoofer Amp - Infinity
Subwoofers - Two 15" Kicker CVR's Electrical - Big 3 and Stinger Battery
Lspade is offline
Old 08-11-2006, 10:50 AM   #93
Lspade's Avatar
Ok, I went under the hood and took some pictures. I could not find the engine to chasis. These are the three that I found:
<br>
<br>
<br>
<br>
<br>
<br>
Do you think I should make a ground leading from the Engine to the chasis??? If you say yes do you think it would be proper to use the ground on the engine that leads from the negative on the battery, use that ground on the engine to hook to the chasis (or if you think it would be better to hook to the frame please tell me )????? Thanks for the help.
Haha, this is hard enough, in one of my friends 3000gt I cant even fit my hand down and touch the alt. Hahaha, thank god for big vehicles.
HU - Eclipse CD3000
Lspade is offline
Old 09-08-2006, 07:11 PM   #94
hooked on fullsize
tahoehtp's Avatar
I got 2ga wire from advanceautopart today so I'm gonna do this tomorrow as well. I alreayd has ground wire going to engine and body so just adding one from alt to batt. I got the HO alt and red top so this will help putting that ampage going through.
tahoehtp is offline
Old 09-09-2006, 02:57 PM   #95
hooked on fullsize
tahoehtp's Avatar
I added the 2 gauge from alt to redtop positive, and I had extra wire so replaced one of the wire was going from batt to engine.
and I had prob with HO alt which shuts off when I'm at stop sign.... so I put back OEM 100amp. but man I do see the difference.
this is good ting I did.
tahoehtp is offline
Old 11-19-2006, 03:35 PM   #96
Anti Ford
Knuckles's Avatar
Holy! 2 gauge. That's fat. You can weld with that. lol
1989 Chevrolet C1500 (4 $ALE = $200)
1991 GMC C1500
Knuckles is offline
Old 12-05-2006, 02:47 PM   #97
formerly bagged 04
Bradford's Avatar
I did my big 3 upgrade with 0/1 awg
Originally Posted by lowryder99
If Jesus built a two linked truck then guess what...Jesus did it wrong too!
Bradford is offline
Old 12-16-2006, 07:58 PM   #98
Cars & Guitars
04SilveradoMykk's Avatar
I did my big 3 a little different. but not much, I went from Alt-Bat, Bat-frame, Bat to firewall and used the factory braided ground to the block.
the black cable is going to the frame, the silver to the firewall, the blue to alt... the smaller guage wireing is for the MSD 6a. Soon the LS1 fans will also be hook up to that jungle of wires.
used a factory stud on the firewall that had a braided ground to the back of the engine block
since hooking the ground to frame it sounds as though the fuel pump pre-start purge has picked up in speed... always a good thing when the fuel pump can recieve more voltage.
Vortec 357ci SBC
Cardomain Link : YouTube Link : Myspace Link
Custom PCM Tuning
04SilveradoMykk is offline
Old 12-19-2006, 06:29 PM   #99
is it a common problem for them to dim. the stock ones?
coondogz71 is offline
Old 12-19-2006, 11:39 PM   #100
"Switching to Guns"
opsbear7's Avatar
umm..ok maybe a dummy quesiton but i dont wanna screw up...I understand EVERYTHING, but hooking it all up to a stock battery. I saw that i will need the stinger gm battery adapter. But what does that do for me? Do i still get the 0 gauge battery adapter ect? Thanks!
03 Silverado 1500 - 6" FIT - Magnaflow - Volant - Blackbear - Procomp Xtreme M/T's - 520 SMR Piaa's - In Dash CB and Scanner - OEM Clearance Lights - Colormatched
opsbear7 is offline
