Old 02-17-2007, 01:59 PM   #101
ATMINF's Avatar
Re: NBS Big 3 upgrade
Can anyone tell me how much wire they used total and then give the break down per wire please?
Exactly how much was the;
1. + battery to alt=ft??
2. Block to body = ?? ft
3. Neg- battery to Body = ??FT
I have heard several different total lenghts (10ft-20ft total) and just wanted to know what the break down was. Thanks so much for the info.
Thanks
2001 Burban 3/4 ton-SOLD
68 Camaro (still building)
95 Camaro Supercharged and other stuff-SOLD
2006 2500HD Silverado LS ExtCab 2WD 6.0L
ATMINF is offline
Old 02-18-2007, 10:33 AM   #102
eBay-aholic
x6369x's Avatar
Thanks
Originally Posted by x6369x
List of supplies:
1) battery positive to alternator (approx. 4’),
2) battery negative to chassis (approx. 4’),
3) engine block to chassis (approx. 5’),
4) 4 ring terminals,
5) heatshrink (to cover ring terminals),
6) flex loom (I didn’t use any because the Stinger wire was so pretty).
The # of ring terminals depends on the type of aftermarket battery terminaly you use.
If you want more accurate measurements of the lengths, run pieces of string or wire from point A to point B, then measure it with a tape measure.
x6369x is offline
Old 02-18-2007, 07:09 PM   #103
ATMINF's Avatar
Thanks for the heads up!
ATMINF is offline
Old 03-10-2007, 06:38 PM   #104
eBay-aholic
x6369x's Avatar
Just thought I'd update the post with some changes I made a while back ...
I changed the alt pos to battery from red to blue wire (this also gives a good view of the ground from the alt bracket to the firewall ground) ...
Then added 2 runs of 1/0 from the pos side post to 2 circuit breakers (the 140A/160A were only temporary, they are now both 200A) ...
Here you can see the 2 1/0 neatly routed through the stock door sill channels ...
x6369x is offline
Old 03-10-2007, 07:10 PM   #105
Cars & Guitars
04SilveradoMykk's Avatar
I did the same thing to run power to the power inverter for my PS2, but over on the passenger side... I'll probably use the driver side for power to the amp when I do subs
Vortec 357ci SBC
Cardomain Link : YouTube Link : Myspace Link
Custom PCM Tuning
04SilveradoMykk is offline
Old 03-12-2007, 07:20 PM   #106
DRK
There's a lotta good info in this thread, but I saw some glaring safety problems in some of the replies.
I come more from a car audio background than a fullsize Chevy one, and I've only had my 02 'Rado for 2 years. However, I've had plenty of experience when to comes to car audio, and I know that it's VERY important to put an inline fuse on the positive link. The positive factory link you are supplementing is fused for a reason. If you don't fuse the additional positive link you are putting in, you risk burning your entire vehicle to the ground if your electrical system shorts out.
Would you rather replace a $2 fuse if you get a short, or the entire vehicle because you were too lazy to wire in a $10 inline
fuse setup?
Also, in the case that your sound system's capabilities far exceed that of your alternator (entirely possible for any of you who might compete in SPL competitions), a properly sized fuse on that link will protect your alternator from working harder than it should in case of massive over-draw.
Just my $.02, I'm new to the forums and look forward to some interesting discussions!
DRK is offline
Old 03-12-2007, 10:09 PM   #107
spark plugs are for cars
VortecZ's Avatar
I'm getting ready to do this big three thing when I install my system. Any of you guys that think the fuse is necessary, what size fuse should it be?
VortecZ is offline
Old 03-12-2007, 11:40 PM   #108
DRK
The size fuse you put in should be the max rated amperage of the wire you are using, which will be somewhere in the neighborhood of 225 to 325 depending on the size and quality of the wire you are using. If you are using 1/0 gauge, it's probably in the neighborhood of 300 amps, so put in a 300amp fuse.
DRK is offline
Old 03-21-2007, 10:48 AM   #109
ok, so ic I run the big 3, should I just find the factory grounds and run parallel to them?
'07 Chevy Silverado C1500 ECSB Superchips programmer
'93 Chevy K1500 ECSB-SOLD
Vaquero is offline
Old 03-22-2007, 09:47 PM   #110
Anyone done this to a diesel yet? Is it neccesary with 2 batts?
2002 GMC 2500HD CCSB 4x4
Duramax / Allison
dag4566 is offline
Old 03-23-2007, 06:01 PM   #111
The Total Package
If you make the size of the fuse equivalent to the size of the wire, then you are not really using the fuse correctly. You should make the fuse LESS than the wire, so it will blow in an emergency. I would think the fuse should be right above the rating of the amp, so if their is a problem, it will blow...
packge33 is offline
Old 03-29-2007, 07:52 PM   #112
Beyond Reality
Just did the big 3 with 4 guage, should i be fusing the wire from the battery positive to alternator and if so, what amperage of fuse?
04 Silverado RCSB: 20" AR Torq Thrust St/Falken Ziex ST/Z04, Gibson Cat-back, Belltech 2" Drop Shackles, Escalade Handles, Debadged, Carriage Works Billet Grill, Truxedo LoPro Tonneau, Ungo Pro Security S660 Alarm, Premier DEHP9800BT, Premier PRS-D2000T Amp, Premier TS-W1007D4 Subs.
AlwaysFollowed is offline
Old 03-31-2007, 02:53 PM   #113
4wdC5's Avatar
Just wondering, are any of you guys running a power capacitor as well?
4wdC5 is offline
Old 04-15-2007, 02:59 PM   #114
DRK
Good point, though I always just assume a fairly low max current for the wire, so it ends up working out the same.
But yes, subtract 10-15 amps from the maximum current the wire can handle for the fuse.
But you can't just put the fuse for the amplifier's max draw, because the wires you are replacing/supplementing are for the entire vehicle. They aren't just for the amplifier. I agree, the power wires for the amps should be fused just above the amp's max current draw, but these are upgrades to the electrical system as a whole, not just the audio equipment.
DRK is offline
Old 04-16-2007, 09:13 AM   #115
Bagged & Bodydropped
Marcos's Avatar
I just did this on my OBS, makes a big difference. I highly recommend this mod...
My Street Source
http://www.streetsource.com/Profile....rofileid=47951
Marcos is offline
Old 04-24-2007, 07:42 PM   #116
hawaiianstyle chevy
Totally lost after trying to ready along with this thread. My take on this is that all I need to do is add two wires to make the flow better in my new 2007 Vortex Max. I'm only going to put in an electric fan from Flex-lite. So will it benefit me by doing the Big Three? Just curious and maybe down the line a new head unit, subs, & amp.
hawaiianstyle is offline
Old 04-27-2007, 10:52 AM   #117
Forum Leader
nebraskaz71's Avatar
I ddi the big three recently on my obs with 0/1 gauge and put in a 270amp alt while I was at it. Only required about 6ft of wire for power to alt, neg to ground, engine to chassis, and i also did cab to chassis. I used a 300amp fuse between battery and alt because thats what my wire is rated at and so far with the stereo fully cranked all lights on ect ect it doesn't drop below 14.5 on hot days ;)
No its not stock height!
Click the signature!
nebraskaz71 is offline
Old 04-30-2007, 08:25 AM   #118
nebraskaz71 do you have any pics of the way you ran your wires, is that 0/1 gauge, welding wire
rolrdz is offline
Old 04-30-2007, 09:37 AM   #119
Forum Leader
I can get some pics....... i used audio power cable
Old 04-30-2007, 12:36 PM   #120
Yea bro that would be very help full, if you can post them up or send them to rolrdz1@yahoo.com, thanks bro
rolrdz is offline
