Old 01-01-2005, 08:53 PM   #21
Exalted512
^^did your mom
Member ID: 13403
Re: DIY, Custom A Pillar Construction Instructions!!
http://www.crashsupply.com/cgi-bin/c.../sem39853.html
cheapest place i could find the spray online...comes out to like 17 bucks...the other 2 places i saw wanted $11 bucks for shipping... are they thinking? 11 bones to ship a spray paint can...
-Cody
04 GMC
system in the works:
Old 01-02-2005, 12:26 AM   #22
ewertro
ewertro's Avatar
Member ID: 13150
Thanks...... now I see pictures. Visualizing things doesn't always work...
another project to try......
Old 01-04-2005, 08:42 AM   #23
HardcoreZ28
Owner RPM Resto & Custom
HardcoreZ28's Avatar
Member ID: 20208
I'm going to be doing this mod soon....two quick questions. What is the optimal direction to point the tweeters? And, my tweeters are Sony's that are about 3" and have no bolt holes for mounting them...any ideas on how to secure them into the pillar from behind?
--== RPM Resto & Custom ==--
1997 1500 Pickup Z71
4" Suspension Lift
Torsion Bars Cranked 1.5 with Ford keys
5.5" Angled Rear Blocks
35 x 12.5 BFG All-Terrains
Old 01-06-2005, 02:45 PM   #24
Exalted512
^^did your mom
Member ID: 13403
every car is different. i tried the exact same set up in my truck and it sounded like ****. the way i like it was the tweeters pointed at the opposite head rest. as far as no screw holes, it sounds like they were designed to be put in some type of mounting cup, you might call sony to see if they have any. another option is if they have a ring around the speaker like 99% of them do, is just to drill your own holes, or if you dont want to drill, they make heavy duty velcro that will be more than strong enough to hold them on. im probably going to start mine on sunday...if all goes well...
-Cody
04 GMC
Old 01-06-2005, 02:54 PM   #25
HardcoreZ28
Member ID: 20208
The speakers came with doublesided tape to put on the bottom and mount them onto the dash or door panels or wherever. That would look tacky as can be in my opinion. Maybe I can stick them to the A-pillar and just mold around them with the fiberglass then? Maybe cover the tweeter with masking tape or something so the fiberglass doesn't stick directly to it in case I ever have to cut them out? It's such a stupid design. I'll never buy speakers like that off ebay again without going to see them in the store first.
4" Suspension Lift
Old 02-09-2005, 05:13 PM   #26
BogeyBoy82
That STOCK $hit Stank
BogeyBoy82's Avatar
Member ID: 4316
i finally took the time to read this article...good build man...a couple more problems arise if you would ask me...first of all...you cant really texture and paint a-pillars very well...from my experience they get entirely too hot and begin to crack/peel during a TX summer....mainly at the parts where the plastic meets the glass....also...a great way to bond plastic to glass is to get bondo made especially for corvettes...i dunno the brand i just see my friend usin it alot..its called "corvette panel adhesive body filler"...he says with plastic it works 1000x better...
Proud Member of L*ve JLA and AFRF (on a switch)
From Wild to Mild: 2-2 Drop / 2 300.4s on 3 pair of XR comps / 1 1000.1 on 13W7
Old 02-10-2005, 07:34 AM   #27
gabe8501
Creamy-Goodness
Member ID: 13124
Originally Posted by BogeyBoy82
ia great way to bond plastic to glass is to get bondo made especially for corvettes...i dunno the brand i just see my friend usin it alot..its called "corvette panel adhesive body filler"...he says with plastic it works 1000x better...
Bogey, ask your buddy if it is called "Vette Filler". I heard about that from someone else around here. A body man at a chevy dealership told my it may be used to repair dash pads/boards.
Originally Posted by 95stroked1500
no wussy excuses that you need $10 to buy your dime bag of weed this weekend.
Dead '85 K10
'01 Z71, Westers 89/93, Premier 880PRS, Dayton RS180's/DLS Ultimate A3, LPG's/DLS Ultimate A2, 2 12" Diamond D6's/ DLS Ultimate A6, and the dreaded 6" torsion bar crank.
Old 02-10-2005, 08:57 AM   #28
DSZ71
100% Roots Rocka
DSZ71's Avatar
Member ID: 4322
Here is something similar, bonds to everything under the sun (its the liquid plastic filler)...http://www.hzemall.com/hzemall_folde...nlinestore.htm
**My Little Roots Rocka**
Old 02-10-2005, 04:00 PM   #29
Exalted512
^^did your mom
Member ID: 13403
im about to do that to my truck, well see how everything holds up. its kinda strange they would make something like that for dashes and stuff which are in direct sunlight and not be able to hold up to the heat??
-Cody
04 GMC
Old 03-28-2005, 12:29 PM   #30
scoobie
Member ID: 23310
how do you create the shape from your mold of the pillar is it with all hot bondo?
Old 03-28-2005, 01:20 PM   #31
Exalted512
^^did your mom
Member ID: 13403
heres my page about it, it might help with your question
basically you get a mounting ring for the speaker, place it where you want it, put fleece over it, fiberglass that, bondo everything smooth and voila
http://www.sounddomain.com/memberpage/531337/10
-Cody
04 GMC
Old 05-16-2005, 03:36 PM   #32
Bostonian Fats
Member ID: 17717
liquid plastic for not so big of projects that don't need strength(so simple pods with tweets). might have to order it. but alittle goes along way. much easier than using FG. wish I'd known about this stuff before. steve meade might have posted this already but he used some. he can probably attest to how simple it is and how much easier it is to get a prettier result than FG. here's his link from termpro.
http://audioforum.termpro.com/ubb/ul.../t/001770.html
Old 06-18-2005, 04:18 PM   #33
TXChev496
TXChev496's Avatar
Member ID: 29388
I have my a-pillars smoothed and painted to match my truck but I want to fiberglass the passanger side and have two tme-m580 alpine 5.8 screens glassed into there to go along with the triple gauge pod on the drivers side with my gauges?? Does anyone do this and can tell me what would be a good way to start it off or do they do it for money and can make one for me?? --Alex
--2004 Silverado CCSB 2500HD 4x4 Vortec 8100 8.1 Liter Engine, Weld Evo Velocity XT 20x10s, 41/14.5/r20 SS IROKS, 12" Candy Blue Cognito Lift (16" lift total), much, much more..
--2004 Silverado CCSB 2500HD 4x4 Duramax LLY Shaved & Slammed, In Progress....
BUILT NOT BOUGHT
Old 06-19-2005, 02:46 PM   #34
Bostonian Fats
Member ID: 17717
look at the link above your post that happens to be in my post.
Old 06-19-2005, 05:33 PM   #35
TXChev496
TXChev496's Avatar
Member ID: 29388
I looked at the post in the link in the post above mine and it shows how to do a dash but not how to do screens into my a-pillars. I have not seen it anywhere where people have put screens into a passanger side a-pillar. I was wondering if anyone has done that or can help me with doing that OR would like to be paid for doing a custom one for my truck?? --Alex
BUILT NOT BOUGHT
Old 06-28-2005, 09:36 AM   #36
Exalted512
^^did your mom
Member ID: 13403
have you called west coast customs?
04 GMC
Old 06-28-2005, 10:13 AM   #37
TXChev496
TXChev496's Avatar
Member ID: 29388
i should. Maybe Mad Mike can hook me up. But id really like to do it myself to save on cost and plus, Id like to learn how to get more in depth with fiberglassing. --Alex
BUILT NOT BOUGHT
Old 06-29-2005, 09:09 PM   #38
Bostonian Fats
Member ID: 17717
it's the same concept. make a square to house the screen and mold it to the pillar with the liquid plastic. that's about as simple as it gets.
Old 07-01-2005, 02:15 PM   #39
rs4647
Member ID: 25807
lmfao
Old 12-18-2005, 02:24 PM   #40
Crazz
Member ID: 32954
thanks, this is one awesome thread.
