Old 11-07-2005, 02:50 PM   #61
I pee'd in your drink
Re: New Door Pods (Work Log)!
Originally Posted by Capt.D
Mine are a little different....You'll enjoy them....
Nice job, but holy protrusion batman!
Damian - I'll say it again: Looks GREAT!!@
Audio system buildup
ibthumpin is offline
Old 11-07-2005, 06:55 PM   #62
100% Roots Rocka
DSZ71's Avatar
Hmm not really. Those stick out way too far mane. How did you make those? A bunch of spacers over the OG grill, then some fiberglass and body filler? I would have at least cut out the grill, and allowed the speaker to fit into it. giving it a much smaller profile. They kinda stick out like a sore thumb, especially with those grilles on them...not trying to be a dick, but those dont look good IMO...sorry...
**My Little Roots Rocka**
DSZ71 is offline
Old 11-08-2005, 08:36 AM   #63
Capt.D's Avatar
They are complete enclosures....the grills and all are removed....that was the airspace needed for the kicker ss components....they mount inside the doorpanels then the panels go over them....keeps the mids tight and no resosance inside the doors.....
Capt.D is offline
Old 11-08-2005, 08:57 AM   #64
100% Roots Rocka
DSZ71's Avatar
Thats what I thought was the reason, however most midbass drivers work well in an IB (infinate baffle) enclosure. That can be achieved by sealing the inside of the door with sound deadening matte. It essentially uses your entire door as the enclosure. Or another approach would be whats called "The Tupperware Method" which is basically you get a tupperware bowl that fits your airspace requirements, make a fiberglass mold of it, then use that to mount INSIDE the door panel as your enclosure, then your speaker could sit flush to the door panel.
DSZ71 is offline
Old 11-08-2005, 06:15 PM   #65
Capt.D's Avatar
The problem comes in im clearing the large magnets on the ss's when installing 2 in each door...Felt it was best to make them even and completely sealed from the elements....The doors are completely dynamatted and sealed also....
Capt.D is offline
Old 11-09-2005, 02:47 PM   #66
HDMLNIUM's Avatar
Looking forward to my set Damian, I can't wait to listen to her after everything goes in..
Bill
04 GMC Sierra Z71
05 CTS-V
Online Photos http://photobucket.com/albums/v466/HDMLNIUM/
HDMLNIUM is offline
Old 02-17-2006, 04:28 PM   #67
100% Roots Rocka
DSZ71's Avatar
Hello...just a note that I will be posting some new pics cause I am building some new pods to house some Dayton RS180 (7") mids and some Dayton RS28 (1" tweeter). I will most likely not show the beginning stages since its basically the same as the rest of the build pics, I will show however the pre-vinyl test fitment and the finished product shots after I install them in my truck.
DSZ71 is offline
Old 02-17-2006, 05:25 PM   #68
Brianm's Avatar
I was looking at those speakers. How do they sound? How much wattage to do u have goin to them? Thx
Brianm is offline
Old 02-20-2006, 01:39 AM   #69
wow man nice work
laynlow77 is offline
Old 03-19-2006, 08:33 PM   #70
formerly Phantom Dually
496-TKO's Avatar
I just installed a set of the Kicker SS series mids and tweets into my 94. Should I seal the whole door off?? I have deading material on the door and behind the speaker. I still am not getting the mid bass I want though. Anyone have a good idea here? 6.5" mids and 1 " tweet
1992 Stepside 496 CID ladderbar rear suspension adjustable coilovers belltech springs in the front and djm spindles. See my gallery for progress pics!!
496-TKO is offline
Old 03-19-2006, 08:37 PM   #71
fknlow
cajundragger's Avatar
make small sealed boxes for the mids using tupperware as a mold for the fiberglass.....I dunno though, Im bout to do this with mine just to see. Its confusing though because most of the time I hear IB is the way to go....I need to deaden first though...
2000 ECSB, 5.3, magna flow cat back, some beat in the back and a killer front stage
cajundragger is offline
Old 03-19-2006, 09:10 PM   #72
496-TKO's Avatar
Someone used to sale IB of some type.
496-TKO is offline
Old 03-19-2006, 09:12 PM   #73
fknlow
infinite baffle is just created in the door when you have a speaker playing in a not so perfectly sealed box....we all have it if we deaden everything as far as I know, unles Im screwing things up....
Old 03-19-2006, 09:15 PM   #74
496-TKO's Avatar
Would these work you think??
496-TKO is offline
Old 03-19-2006, 09:17 PM   #75
496-TKO's Avatar
Well I just read a few reviews on these and by what others say they sound like ****.
496-TKO is offline
Old 03-19-2006, 09:18 PM   #76
100% Roots Rocka
DSZ71's Avatar
Infinite baffle is made by running a driver in an enclosure thats just way too big for it, and its created when you deaden your door and seal it off, baically creating a box thats too large.
For example, you can run a 10" woofer on the rear shelf of a car, using the trunk (properly sealed of course) as the IB enclosure. although not all subs or drivers are suited for this type of enclosure, so make sure yours will be. Most midrange drivers are fine though, its the subs you need to be more picky about.
DSZ71 is offline
Old 03-19-2006, 09:28 PM   #77
496-TKO's Avatar
So would it be good to seal off everything on the door with Dynamat? Vents and all? I really am not getting no where near the midbass these speakers can put out. Thx
496-TKO is offline
Old 03-19-2006, 09:34 PM   #78
100% Roots Rocka
DSZ71's Avatar
Yes, although use a better priced alternative to Dynamat...called RaamMat BXT (www.raamaudio.com)
Just dont cover the speaker hole, but do everything else. I did a layer on the insides of the metal door panel, then did 2 layers over it to seal it off. Here is a pic of my door panel once I started and after I was finished:
Doing the inside of the panels -
And all done -
DSZ71 is offline
Old 03-19-2006, 09:45 PM   #79
496-TKO's Avatar
Thx man. My truck is a 94 W/T 2500. Sound deadening was not a prority!!
496-TKO is offline
Old 03-19-2006, 10:08 PM   #80
fknlow
haha thank you, that was what, lesson 537?
