Old 06-22-2008, 01:55 AM   #101
What should I put here...
Originally Posted by 1MeanC3
Also, what would you reccommend for the x-over's? I currently have them both amps set to 80hz.
the xover between your subs and main speakers should be set between about 60 and 80 hz so ur good there
1993 FORD ESCORT LX SEDAN
1978 CHEVY C10 SCOTTSDALE, 2 DOOR, LONGBOX(BIG 10) 350CI 4BBL V8
chubyboy is offline
Old 06-25-2008, 12:34 PM   #102
Hi sorry I cannot help you because I don't have any idea about this matter
Digital Video Editing
sunnatsam is offline
Old 08-31-2008, 10:53 AM   #103
Operational Amplifiers
The operational amplifier is arguably the most useful single device in analog electronic circuitry. With only a handful of external components, it can be made to perform a wide variety of analog signal processing tasks. It is also quite affordable, most general-purpose amplifiers selling for under a dollar apiece. Modern designs have been engineered with durability in mind as well: several "op-amps" are manufactured that can sustain direct short-circuits on their outputs without damage.
ayt?
hAppY010 is offline
Old 09-22-2008, 11:11 AM   #104
Cardsin2005's Avatar
My friend and I were checking the clipping volume on our head units last night. The oscilloscope reading told us that nether of our decks clip at full volume and flat eq and no other enhancements on. (witch is how we listen to it anyway). Does this sound right. That nether of the decks clip at full volume. IDK how the oscilloscope could be wrong since it is a visual output.
1995 Tahoe. 5.7L V8 4x4
Custom green cab lighing, cab visor, custom cat back system w/ Flowmaster 50 Series muffler.
Custom Kenwood Sound system.
Cardsin2005 is offline
Old 01-29-2009, 10:07 PM   #105
this has helped me a lot, mad props on this post
89stepside18 is offline
Old 03-04-2009, 02:53 PM   #106
Life Is Good
Motley aka Yeti's Avatar
hey man, i read through but i'm pretty confused. here's what i'm working with:
http://www.fullsizechevy.com/forums/...p-my-subs.html
i understand the concept of the setting formula, just not sure if i'm doing it right.
i think this is the formula that will work.
V=sqrt (250w RMS x 4 Ohms)
V=sqrt (1000)
V=31.6
1998 z71, 5.7L 350, 4wd- 6k HIDs
Motley aka Yeti is offline
Old 07-26-2009, 01:19 AM   #107
Money Pit
Originally Posted by jntar View Post
Congrats...if they ever fail you know what when wrong. 2 things kills a speaker. Thermal failure and mechanical failure. Setting a gain by ear doesnt keep the amp from clipping. Clipping will cause excess heat and eventually ruin the speaker. This isnt a guarantee, but its a main cause. I can only suggest you set it with the formula in the first post.
hey I have a 3 year update with ALL THE SAME SETUP my method worked for me as i tuned my stereo for 30 of 35 but listen to it on 22, its not luck either, I think I could find something rare and the next day 4,000,000 of the same things would be discovered
Originally Posted by mgrotel
are you kidding me? id be shooting my load in one of those long tubes if it wouldnt burn my peter
tylers88 is offline
Old 08-18-2009, 05:34 PM   #108
AGChoset's Avatar
nevermind...
AGChoset is offline
