Old 05-23-2006, 09:26 PM   #1
Poor college student
02+ Radio installs
As a lot of you guys know, the newer Chevy/GMC trucks are a little odd as far as installing an aftermarket radio.
Most of you have 2 options
Option 1:
Buy the Metra 70-2003 harness, find an accessory power and be done with it. You will lose your door chimes. That is all on MOST models.
Option 2:
Buy the Metra GMRC-01. This is a $100+ harness. The ONLY thing it does is retain the door chime.
So whats the difference?
The difference is your trucks computer. GM has integrated some of the diagnostics to show across the radio. For instance, the "Low Engine Coolant" and messages like that will stream across your radio's display.
If you don't have RDS, you will never have to worry about it. You can buy the 70-2003 off eBay, your local audio store, or best buy/circuit city.
If you DO have RDS, its not the end of the world. If you have a message center in your instrument cluster that displays your engine's diagnostics and nothing shows on the radio, then you're okay with the 70-2003.
Hope this clears up some things.
-Cody
04 GMC
system in the works:
Exalted512 is offline
Old 05-23-2006, 09:44 PM   #2
Re: 02+ Radio installs
Shouldn't that be "03+" ?
My Truck
Nick is offline
Old 05-24-2006, 07:09 AM   #3
yeah 99-02' use one adapter and 03'+ trucks have another. I have an 01 Tahoe non-Bose with Onstar and I needed the metra GM 70-2006.
badboyztn is offline
Old 05-24-2006, 07:28 AM   #4
some 02s use the 70-2003, but youre correct, most still use the 70-1858
-Cody
04 GMC
Old 05-24-2006, 03:57 PM   #5
-Cody
Just pointing out that they started using the Class II databus in '03.
My Truck
Nick is offline
Old 05-24-2006, 09:22 PM   #6
I pee'd in your drink
So when would you need the GMRC-01 since it "only" retains the door chime?
And I thought all the clusters in the NNBS were the same -in that they had a display for the warnings.
Audio system buildup
ibthumpin is offline
Old 05-24-2006, 10:04 PM   #7
you only need the GMRC-01 when you have diagnostic messages that stream across your radio. Its very rare to have to use the GMRC-01 in trucks. Ive run across 3 trucks Ive had to use that module in a year of installing professionally. Most of the time youll find it used in Impala's.
-Cody
04 GMC
