01-03-2008, 10:57 AM
#181
Supporting Member
Originally Posted by thekl0wn
Everyone has projects they've deemed more important for me to be doing. I think in an entire 2 weeks off I only had time to do about 10-minutes worth of filler on it.
 isn't married life the best?
01-03-2008, 11:07 AM
#182
Future Dirty Old Man
Married...  Granted, it has been the new lady friend that's kept me out of the shop most of the time.
01-03-2008, 11:11 AM
#183
Supporting Member
ehhh... I was close, I knew it was because of a female - it always is
01-05-2008, 11:31 AM
#184
Donations Accepted
01-08-2008, 10:20 PM
#185
you can use a relay as a trigger make it shut down by it self when you turn the key off i did it and it worked great no more shuting down and nomore booting i also made a hot swap drive under the ashtry for a reg 3.5 drive
max size is 500 x 200
01-09-2008, 06:38 AM
#186
Supporting Member
Thanks for the suggestion on the relay - I'll be using an Opus powersupply wired to my ignition - that unit will be controlling boot ups and shut downs.
Lets see some pics of the hot swap drive.
01-09-2008, 07:30 AM
#187
 and
The modern "smart" power supplies are a blessing!
01-23-2008, 06:28 PM
#188
Supporting Member
well this isn't good.
Planning on doing the install this weekend - working now to get everything ready. Got the front end installed and somewhat configured... can't get the frickin screen to work! I really hope I didn't damage it while building the bezel.
01-23-2008, 11:24 PM
#189
if its not cracked it should be ok
'99 Sierra 1500 4x4 Z71. 90* Flowmasters, 285 M/T 10" Alpine
Go Dawgs!
01-24-2008, 06:14 AM
#190
Supporting Member
yeah I got it somewhat working last night. In my inebriated state, I forgot one cable that was removed during the build. Found that and it fired up. I can't get the screen adjusted so the 'picture' is centered and makes use of the full screen. I'm going to install it in the bezel tonight and see if I can get it to adjust.
01-24-2008, 01:58 PM
#191
damn that looksgood as hell
01-24-2008, 03:39 PM
#192
That sucks about the screen. What brand was it again?
01-24-2008, 03:42 PM
#193
Supporting Member
the brand was 'datalux' but I'm not sure who made the actual panel.
What really sucks is I was planning on getting this damn thing installed this weekend. Oh well I guess I'll get it all installed except for the monitor if I can't get mine working and when a new one arrives, just pop the case and drop it in.
01-24-2008, 03:55 PM
#194
A little duct tape and some bailing wire, and you should be able to get it to fit!
01-24-2008, 04:42 PM
#195
formerly bagged 04
That sucks about the screen. Hope you figure it out.
Originally Posted by lowryder99
If Jesus built a two linked truck then guess what...Jesus did it wrong too!
01-24-2008, 06:43 PM
#196
This is a nice build. I believe I may of seen this build on a fiberglass forum as well.
01-25-2008, 06:06 AM
#197
Supporting Member
oh yeah - not sure what happened to all the pictures - it looks like most of the early ones are gone from my photobucket. I'll do my best to get them back up this weekend.
01-25-2008, 01:40 PM
#198
Supporting Member
question for you guys. I'm using a slot load dvd drive with the slimline CD to IDE adaptor here:
I know the IDE connector is the big one. One of the other 3 (4pins) is for power leaving the other 2 are for analog audio. Anyone know which of the 4 pin is for power?
01-25-2008, 02:32 PM
#199
01-25-2008, 02:39 PM
#200
Supporting Member
thanks man!
Obviously I suck at searching - I've been going through carmp3 for almost 1 1/2 hrs now.
| Thread Tools |
| Display Modes |
Linear Mode
