Old 05-09-2008, 01:39 PM   #1
Z71RedNeck
Member ID: 65334
12" help!!
I have access to a 12" sub and an amp for free. My truck is a 97 ext cab . Any ideas on how to make this work? I do not think a box for that sub will fit under the seat.
Old 05-10-2008, 02:53 PM   #2
///M5
///M5's Avatar
Member ID: 40623
Re: 12" help!!
It depends on a ton on the 12. What is it exactly/
Old 05-11-2008, 10:10 AM   #3
Z71RedNeck
Member ID: 65334
Re: 12" help!!
Here are the specs. I was thinking of a box that ent behind the driver seat and underneath the back seat. I am very new to this and that is about the best way I can come with to do it. Noone ever rides behind me so losing that room is not a big deal.
Model: SRW3041
Maximum Power Handling ...................................500W
Continuous Power ................................................25 0W
SPL .................................................. ....87.0dB@1W/1m
Frequency Response ................................20Hz-1.5kHz
Cone Material .....Polypropylene w/Titanium Deposition
Woofer Magnet ..........................Strontium Ferrite 33 oz
Woofer Basket .......................................Stamped Steel
Cone Surround Material ............................NBR Rubber Sealed/Acoustic Suspension
Thiele/Small Parameters
Vented/Bass Reflex
OPTIMUM
Enclosure Airspace (Unfilled) =1.25 ft3
Enclosure Airspace (Filled) =1.04 ft3
F3 = 42 Hz
MAXIMUM FLAT
Enclosure Airspace = 2.50 ft3
Fb = 32Hz
F3 = 30Hz
Port Size = I.D. x Length: 4" x 11.5"
• Polypropylene Cone
• Rubber Surround
• 4 Ohm Heat Resistant Voice Coil
• Rear Vented Pole Piece
• Large Strontium Ferrite Magnet
• Rubber Magnet Cover
• For Small Sealed or Small Vented Design
Outside Dia 12 1/4" (311.2mm)
Mounting Hole 11" (279.4mm)
Mounting Depth 5 11/16" (144.5mm)
Sensitivity@1W/1m 87.0dB
Max. Peak Music 500W
Continuous Power 250W
Nominal Impedance 4 Ohms
Re DC Imp (± 10%) 3.25 Ohms
Le 2.64mH
V.C. Diameter 2.0" (50.8mm)
V.C. Length 0.961" (24.4mm)
Air Gap 0.314" (8.0mm)
Piston Diameter 10.37" (0.2635m)
Sd 84.5 in2 (0.0545m2)
Vas 2.16ft.3(61.17liters)
Fs 35.3Hz
Qts 0.75
Qes 0.83
Qms 7.77
Mms 139.2g
Mmd 132.0g
Rms 3.98kg/s
BI 10.9 Tm
Speaker Displacement 190in.3(R)/140in.3(F)
Xmax 0.37" (9.4mm)
Magnet Weight 33 oz.
Clarion Corporation of America 661 W. Redondo Beach Blvd., Gardena, CA 90247
Phone: 1-800-GO-CLARION FAX: (310) 327-1999
60
70
80
90
100
110
10 100 1000 Hz
60
70
80
90
100
110
10 100 1000 Hz
21A3985
dB
dB
Old 05-11-2008, 10:53 AM   #4
0000
Member ID: 85941
Re: 12" help!!
i just set mine on the backseat. it moves around alot but other then that it is fine.
Old 05-11-2008, 06:03 PM   #5
///M5
///M5's Avatar
Member ID: 40623
Re: 12" help!!
1.25 and 5 11/16" shouldn't be a problem to put under the rear seat of an NBS. :)
Old 05-11-2008, 06:22 PM   #6
gmctrucks
Member ID: 58218
Re: 12" help!!
Place it in the center of back seat for now you just might like it there.
Old 05-12-2008, 12:58 PM   #7
Z71RedNeck
Member ID: 65334
Re: 12" help!!
I was thinking of maybe building a box/center console for the back seat. I dont really want the speaker to show do to the fact that I have dogs that ride back there. So the plan was a down firing box that comes up from the floor board and over the seat. The sub would be down firing onto the seat and I am not sure how that would sound.Any ideas on that? I could have the sub maybe up firing with a git-r-done speaker gaurd on it.
