Old 03-25-2003, 04:23 AM   #21
GLN305
Member ID: 5534
I visit this forum to see what everyone is talking about even though I have a Dodge Dakota. Maybe you can help me with my alternator problem. I had it re-wound and at idle it doesn't put out the current I need. I am looking for a 7 or 8 rib pulley that's 1.9" in diamter or smaller that will work. The alternator is a 136-amp Nippon Denso and it's in a 2000 Dodge Dakota R/T. If you can help it would be great!! Thanks!
Old 03-25-2003, 01:55 PM   #22
Sammy004
97 Z71
Sammy004's Avatar
Member ID: 4482
Hey bobby mac it looks like the one on the bottom pic.
Old 03-25-2003, 08:38 PM   #23
Bobby_Mac
Need more Power and Bags
Bobby_Mac's Avatar
Member ID: 4069
Looks like you may have to go aftermarket to get more power Sammy004.
AFAIK the alternator you have doesn't have any higher amp stator or rotar. Or we don't have any in our shop.
You can probably get yours rewound to get more juice form it.
The year of you truck showed that it had an optional 124amp alternator which is a big housing alternator.
like this:
Now i don't know if it will just plop in there. What i did on my truck was get an alternator similar to the one in the picture and used a different bracket to mount it. Braught it up to 140 amps.
GLN305:
Does it put out more or less at idle compared to before.
So im guessing its only at idle that it is not putting out the current you need, and if you rev it up then it put outs what you need?
If so then you can go to an alternator shop and tell them you got your alternator rewound and you want to try a smaller pulley on it. But if i put a smaller pulley on it make sure to check to see if you belt is tight enough. If you are going alot smaller then the belt may need to be changed.
Lemme see at work tomorrow how small of a pulley we have, also how small of a pulley we can get. So are you not sure on whether its a 7 or 8 groove pulley? I'll check for both.
Old 03-26-2003, 02:37 AM   #24
GLN305
Member ID: 5534
It is a 7-rib, but I have been told that I can use an 8-rib. My current pulley is 2.4" in diameter where the belt sits. Thanks for looking for me, you may be a savior if you can find one that works!! I forgot to say that it puts out less at idle than the factory unit. I think he may have gone too big on the stator...
Old 03-26-2003, 01:51 PM   #25
Sammy004
97 Z71
Sammy004's Avatar
Member ID: 4482
Bobby-mac where can I get this 124 amp alternator from the high performance and do you have the model # of it. also would you know the amps of my alternater the stock one thats in there now.
Old 03-26-2003, 08:23 PM   #26
Bobby_Mac
Bobby_Mac's Avatar
Member ID: 4069
At the shop we call it CS-144 i think
In that casing you can get a 140amp version. You may have to go to a local Alternator shop and ask if they can make it fit in your truck. One of my co-workers made it fit in my truck, he had a bracket laying around and just modified it and it worked.
I beleive your stock alternator is either 100 or 105 amps.
GLN305: sorry it totally slipped my mind today. I'll make sure to check on that tomorrow. I'll write it on my forehead backwards or something.
Old 12-15-2003, 05:31 PM   #27
gomer23
Member ID: 4698
Right now I have my stock 105 amp alternator is there a limit to how big of an alternator I can get? Like, I'm going to be upgrading to something in the 200 range and want to make sure i won't have any problems.
Old 01-11-2004, 12:52 PM   #28
NTJeepster
NTJeepster's Avatar
Member ID: 8515
Re: Alternator suggestion
Originally posted by TigerEyz3
97Silverado... Great explanation!!!
redsled...I don't know if you are still looking for an alternator or not, but I just replaced mine - went from 105A to 220A. Call Dominick and tell him what you have and what you are looking for as far as output. He builds a wide output range of alts so at least one will suit your needs.
I would suggest contacting him before you purchase elsewhere. I have been very pleased with my purchase.
phone: 615-287-7991
Click here to email him
Hey TE mind telling what you paid for it ? thanx
82 CJ8 Scrambler
00 GMC Ext. Cab
Old 07-01-2004, 10:41 PM   #29
nn2004
Member ID: 15988
wow..
1987 Chevrolet R10 Custom Deluxe
Stock 350, Th350, 3.42 Rear
Old 09-09-2004, 03:53 PM   #30
Bob T
Premium Member #26
Supporting Member
Bob T's Avatar
Member ID: 13228
How an alternator works? I thought the electrons were scared by the rotor spinning around and ran out the wire. The diodes won't let 'em back in so they gotta stay in the battery.
Old 09-13-2004, 09:44 AM   #31
nn2004
Member ID: 15988
Sounds about right. Diodes are a one way street, and convert the AC current to DC current, so I understand...
Old 02-07-2005, 01:49 PM   #32
DenaliTX
Member ID: 17181
Re: How an alternator works!
my new solution to my alternator problems
Old 06-18-2005, 04:59 PM   #33
TXChev496
TXChev496's Avatar
Member ID: 29388
My alternator on my '04 2500HD is only putting out about half of the amperage that it is supposed to (it is a 145 amp alternator). I am replacing this alternator with a 250 amp alternator for my competition sound system because chevy wont warranty it. What would I need to fix the alternator as it is still working and not totally fried yet?? --Alex
--2004 Silverado CCSB 2500HD 4x4 Vortec 8100 8.1 Liter Engine, Weld Evo Velocity XT 20x10s, 41/14.5/r20 SS IROKS, 12" Candy Blue Cognito Lift (16" lift total), much, much more..
--2004 Silverado CCSB 2500HD 4x4 Duramax LLY Shaved & Slammed, In Progress....
BUILT NOT BOUGHT
Old 01-06-2006, 11:14 PM   #34
KÖNIGSTIGER
in San Diego 'til 09 AUG
KÖNIGSTIGER's Avatar
Member ID: 38864
Ok, Now I got a question or two:
Here's my current situation: Stock alternator and twin KC 150 watters. I need help, they just murdered my stock alternator and had to get it rebuilt (real cheap). I am currently looking at the possibility of adding two more 100 watters, and I obviously need a new alternator. My questions are:
1. How big? I was thinking 140A to 200A? What are some good brands, and does GM make an alternator that big for a 5.7L 350 1996 Vortec? I have A/C, power everything.
2. Will this alternator affect the battery, if so, how?
Thanks!
UIUC CLASS of 2011
TECHNICAL SYSTEMS MANAGEMENT
2007 VW Jetta 2.5 5spd manual
1996 RCSB SILV K1500...SOLD
2007 HONDA RANCHER AT; RT25 WARN, WARN BUMPER, WARN BACKUP LIGHT
Old 02-12-2006, 11:52 PM   #35
macnoma99
Member ID: 41668
nice sticky
Old 03-03-2006, 06:49 PM   #36
cantburn
Burner
Member ID: 33288
great info...thanks
"I Love The Smell Of A Salvage Yard In The Morning"
Old 11-19-2006, 02:42 PM   #37
Knuckles
Anti Ford
Knuckles's Avatar
Member ID: 52540
Can I keep the same voltage regulator?
1989 Chevrolet C1500 (4 $ALE = $200)
1991 GMC C1500
Old 12-17-2006, 09:09 PM   #38
5.7L JWL
5.7L JWL's Avatar
Member ID: 60040
does this work
Old 12-17-2006, 09:13 PM   #39
5.7L JWL
5.7L JWL's Avatar
Member ID: 60040
Had a glich in the system...
Can someone answer this question? What would cause an alternator to "whine" but when you hook it up to diagnostics reader, everything is fine. All systems checkout good. It only has 10K mi. on it.
Old 04-05-2007, 12:20 PM   #40
Erich_121
Member ID: 66568
I had someone tell me that they had a loose ground wire that made it whine which does make sense. CHeck all your connections
2002 Silverado reg cab, short bed
