Old 06-24-2006, 12:29 PM   #21
02hoe
Member ID: 2390
Re: bio diesel
I ran several tanks of it without problems. I was not running 100% bio though it was more like 75% bio and 25% #2. I did not see a mileage increace or any real benefit from running it. Back to #2
03 GMC CC LB Duramax/Allison loaded
02 GMC Denali - Dropped, Giovanna 22's
86 GMC Jimmy - 60 up front and 70 in the rear, H1's, too much other crap
Old 06-24-2006, 06:45 PM   #22
red suburban
red suburban's Avatar
Member ID: 46297
Re: bio diesel
its very true about fuel filters though, i went through at least 5 or 6 within a few months, after that i didnt have any problems.
Old 06-24-2006, 06:51 PM   #23
1toncrew
Member ID: 37611
Re: bio diesel
[quote=GetMore]There are three types of "alternative" fuels for diesel engines, SVO, WVO, and biodiesel.
SVO is straight vegetable oil. TYpically Canola oil.
WVO is waste vegetable oil. This is just used fry oil.
Biodiesel is made by processing SVO or WVO. (Actually they can make it from algae as well.)
Even biodiesel made from SVO will make the exhaust smell like fries.
WVO is usually free, but does need to be filtered, and it will build up deposits in the combustion chamber and injectors. It is very thick, so it will need to be heated to run in most vehicles. The filters and heating equipment, along with the possible maintenance required can add to the cost.
So if you process the wvo using one of these do it yourself machines such as azurebiodiesel's kit, you wont have the problems mentioned in the paragraph above?
Old 06-24-2006, 10:03 PM   #24
dozerboy
dozerboy's Avatar
Status: Online
Member ID: 25211
Re: bio diesel
Correct
Old 06-24-2006, 10:32 PM   #25
1toncrew
Member ID: 37611
Re: bio diesel
just gotta convince the wife to drop 3 g's
So what is involved to make ok to run this stuff. I know youy have to switch fuel lines. Is that just the rubber and not the hard lines? Is there anything on or in the engine that will need modification? It's a 6.5 T.D. Very interested being I use this truck(89 CC v3500) for about everything I do and 3.11 a gal. is kicking my tail.
Also If im down to say 4 or gal. left in the tank of bio and need to fill up, will regular diesel be ok to put in?
Old 06-25-2006, 12:43 AM   #26
red suburban
Member ID: 46297
Re: bio diesel
biodiesel and petroleum diesel will mix with no side effects, its even sold at the pump (if they do in your area) in certain mixes (20/80, 50/50, 100). you will need to replace your rubberfuel lines, but the metal parts are no problem. i made my own processor (an appleseed version) for about 300-350 bucks. consisted of:
1. water heated from the local metal scrap yard (10 bucks)
2. pump, 25
3. about 4-5 valves
4. around 10 ft of 3/4" steel pipe (NOT GALVANIZED!!!! the biodiesel will pick up the zinc in the pipe and carry it into your engine, leaving it deposited in the cylinders, similar to what happens if you use a gasoline fuel tank in your diesel truck)
5. 2 new heater elements (i bought the 120v versions because that was the only outlets i had available where i had mine plugged in)
6. 2 50 gallon oil drums (5 bucks each) one for the restaurant, the other in the truck bed.
7. second pump (to pick up the oil at the restaurant) that runs off of a 12 volt system (150, most expensive part of my system)
Old 06-26-2006, 01:43 PM   #27
GetMore
Member ID: 28812
Re: bio diesel
02Hoe, you will not see a mileage increase. As a matter of fact, there can be as much as a 10% decrease, though that is extreme. Biodiesel does have a lower BTU content. The higher cetane and lubricity usually counteract that, so the typical range is 0-5% drop in economy.
1toncrew, I wouldn't bother buying the prebuilt processor. You can make your own for about 10% the cost, as red suburban mentions. Once you have the system up and running you will find that the methanol is the most expensive ingredient, but if you use a heater and a cooling loop you can recover most of the methanol and reuse it. Removing the methanol from the byproduct leaves you with glycerin. You can use the glycerin as soap or fertilizer, or as a parts cleaner. It's also biodegradable, so it is safe.
Boidiesel will eventually eat rubber lines, but there are lines out there that are compatible. I just can't think of the material offhand. I know that VW changed their lines and seals to this material in the early 90's, so my '97 Passat is ready for biodiesel.
2001 Silverado 2500HD 4x4, 6.0/4L80E
Stock/tow vehicle
Old 06-26-2006, 07:57 PM   #28
Scrufdog
No Spark Plugs Allowed
Scrufdog's Avatar
Member ID: 42713
Re: bio diesel
GM switched to synthetic fuel lines in the early 90's, safe for biodiesel.
1997 Chevy K2500HD Ext/SB 6.5TD VIN F, 4L80-E, Heath reflashed ECM, homemade PMD cooler, #9 resistor, homemade manual boost - 11PSI, hi-flow intake with Fram Boost filter, 3" SS downpipe, 4" straight back SS exhaust, 180 degree SS thermostats, high idle switch
166,000 miles, 17-18 mpg
Old 06-26-2006, 10:06 PM   #29
red suburban
Member ID: 46297
Re: bio diesel
the general rule on the fuel line replacement is if the truck is 96 or newer the lines are fine if 95 or older they need to be replaced. GetMore is right about methanol being the expensive part of the equation down the road, but its still not even close to buying fuel at the pump. before i made my methanol recovery system i was spending about 75 cents a gallon, after the methanol system, 40-45 cents.
Old 06-27-2006, 08:14 AM   #30
skivhere
avatar wizard
skivhere's Avatar
Member ID: 39372
Re: bio diesel
One of the guys at work was telling me about his dad using the biodiesel in his Dodge. He makes it at home and it costs him about 60 cents/ gallon.
Wish I had a diesel...I would convert my whole garage into a biodiesel refinery...prolly against the law in my area, but oh well!! Ahhh...to have cheap fuel again!
C-Ya.....Skiv
Lazy-Dog-Design
Superpimp!
_____________________________________________
1996 GMC 2500<---clicky here!
Old 06-27-2006, 11:41 AM   #31
GetMore
Member ID: 28812
Re: bio diesel
Here is a link to a site selling processor kits, cheap to outrageously expensive: http://www.biodieselwarehouse.com/
Many people set up the processor in their garage. I'd be very careful if I did that, since methanol is very flammable. You just have to take the proper precautions.
Stock/tow vehicle
Old 06-27-2006, 05:01 PM   #32
the moose
Gallons per Mile
Member ID: 25347
Re: bio diesel
http://dieselpowermag.com/videos/
interesting interviews on biodiesel ... just to stimilate conversation a little
95 305tbi 3.73s w/G80rock crawler 97'procomp9000's summit/pace setter shortys dynomax bullet catco hi flow cat (sold)
2004 GTO 6speed kooks long tubes, catless. some suspension etc... thinking of selling for another truck.
Old 06-27-2006, 09:33 PM   #33
Lurius
Member ID: 20376
Re: bio diesel
As for the geling, this is why they usually run a heater system in true biodiesel systems. A great place to get the oil is potatoe chip frying plants, it is supposed to be some fo the cleanest.
-Lurius
Old 06-27-2006, 09:51 PM   #34
red suburban
Member ID: 46297
Re: bio diesel
i set up my processor outdoors in the shade and kept the methanol over where i kept the other flamible liquids like the gasoline and oil, far away from sparks/electricity.
Old 06-27-2006, 10:26 PM   #35
1toncrew
Member ID: 37611
Re: bio diesel
so how do you get some of the methanol back?
Old 06-29-2006, 07:36 PM   #36
dozerboy
dozerboy's Avatar
Status: Online
Member ID: 25211
Re: bio diesel
never mind
Old 06-30-2006, 02:52 AM   #37
red suburban
Member ID: 46297
Re: bio diesel
have to set up a system consisting of 2 tanks, one with the glycerine byproduct and the other empty (at first), that are sealed except for a hose up at the top. heat up the 1st tank that has all of the glycerine in it until a vapor starts to come out of the top (the methanol). the methanol will go to the top of the tank, through the hose into the other tank, the cool and liquify. you dont get all of your methanol back, but i'd say about half of it, maybe a little more.
Old 07-02-2006, 11:32 AM   #38
Big Angry
Chest Poundin' Apes!
Big Angry's Avatar
Member ID: 349
Re: bio diesel
Originally Posted by dozerboy
You have nothing to worry about.
Unless you have warranty issues and you got some in your tank, most dealers are gonna say bye bye. I personally wouldn't do it, but that is my preference.
2004.5 Chevy CCSB D/A LLY
Old 07-02-2006, 07:48 PM   #39
the moose
Gallons per Mile
Member ID: 25347
Re: bio diesel
just do it after warranty is over.
Old 07-06-2006, 09:43 AM   #40
GetMore
Member ID: 28812
Re: bio diesel
Use B20 or lower and don't tell the dealer, and you should be fine.
I don't advocate lying to the dealer if you do something to damage the vehicle, but B20 will not do any damage, while they might decide to claim it is the culprit.
In other words, just don't give them an easy excuse to deny the warranty.
Stock/tow vehicle
