#1 |
Member ID: 43986
95 6.5 liter diesel 3500 HD/standard trans
I have been told there is nothing for my 95 Cheyenne
as far as a programmer is concerned...is this propietery? granted the truck runs like a bat out of hell. none of the truck performance shops have any performance parts or computer programmers that work on this 6.5 liter diesel...have been told that only 95 are the trucks to be left alone...any suggestions? thank you Mike dana 80 differential-dually Off Road Unlimited differential cover part# 6065P $165.99 10 bolt 11.5 ring gear Last edited by Mike Lang : 07-09-2006 at 11:45 AM. |
#2 |
Re: 95 6.5 liter diesel 3500 HD/standard trans
You can chip your truck....check out heath diesel, kennedy diesel, SS diesel and dieselplace.com for more info....
1/4 Mile ET
16.722 @ 80.701 MPH |
#3 |
Member ID: 43986
Thanks for the tips..still haven't found anyone
with the chips for my paticular truck...thank you mike |
#4 |
Did you email kennedy or heath directly?
1/4 Mile ET
#5 |
Member ID: 43986
thanks, still discovering what be done with a 95 6.5 liter T D standard.....if you have a dually flatbed, the differential may very well be a Dana (80)10 bolt cover 11.5 gear
ring . will give the part # for the differential cover just as I find the reciept... thanks so much...know this truck beats the **** out of other diesel duallys hands down as stock from General trucks in Houston hearse driver Mike http://autos.groups.yahoo.com/group/deadcarsociety/ |
#6 |
Member ID: 43986
granted, there is no reason to chip my truck out any further than what it already has. I want to get rid of the 85 mph limit on full throttle. Like I say before, this truck is hell from a standing start full throttle thru the gears, but 85 mph, the engine kicks out...have you noticed with the Roosa/Master (no throttle linkage) the kickback from the petal on full speed throttle on these diesels? Mike
#7 |
Have you put in an intercooler? boost fooler? boost controller? higher resistor value?......
1/4 Mile ET
#8 |
Member ID: 43986
the reason the truck can't get anymore power is that it is a
1 1/2 ton 9 ft.flatbed built by General Truck and Body in Houston,Tex. and chipped out(according to G.T.& B.) to roll on 222/70R19.5 wheels and was built as a 5th wheel flatbed. Only one vacuum hose from pump to vacuum dump valve and then to the turbo, it came with oil and powersteering hydroboost brake coolers.This Chevy is anything but slow from a standstill without breaking a sweat in 3rd gear. it's a Pasadena Tex. redneck nighmare dually. ![]() Last edited by Mike Lang : 07-05-2006 at 11:31 AM. |
#9 | |
hmmm, all places I would avoid... Last edited by gmdieseltech : 08-13-2006 at 08:10 PM. |
#10 | |
DO NOT BUY FROM THIS GUY!!!!!! Do a search for "steaksauce" at dieselplace.com He has been banned from: "dieseldoctor.com, dieselpage.com, and soon to be dieselplace.com" This man is a con artist!!!!! Anyone reading this should do themselves a favor and read this posting to see what 'steaksauce' is all about... http://www.dieselplace.com/forum/showthread.php?t=95586
1/4 Mile ET
16.722 @ 80.701 MPH Last edited by chrisk1500 : 08-13-2006 at 08:48 PM. |
#11 | |
Am I selling something???
I don't think so! More LEBEL from this JoKer! Quote:
#12 |
Really ?? Not selling anything.
The very last thread I read you gave out your web address so sarge could buy a pmd cooler from you. YOU SIR ARE A LIAR. |
#13 | |
Member ID: 32466
Honestly, I was considering ordering the '06 towing mirrors from them, but if there's any possibility that you are in any way related to them, I think I'll pass. As far as libel... you are the one who popped your head up after 2 years and started bashing vendors who have a very solid reputation. I've dealt with Kennedy and Merchant for over a year and have had no problems. |
#14 |
His company is A-1
Thats wy the old name Steaksauce. He is not associated with GM PARTS DIRECT to my knowledge. |
#15 | |
I am in no way affiliated with gmpartsdirect, and you can not buy from them, that's your choice and that's perfectly fine with me! I offered the link to them as a source with low prices.
I also use pace parts and NAPA, AutoZone, PepBoys, Michelin, Bilstein and Goodyear, you can avoid those companies/products too... NOT bashing, just stating facts and giving a heads up on what to avoid and if someone is misled to think I am selling parts I will clear the air! if you were not one of their victims, then good for you! I simply posted a heads-up to help others avoid being victims, that should not be called "bashing". Quote:
#16 |
Sigh. Shouldn't do that.
Look here - he's selling his stuff again. http://www.fullsizechevy.com/forums/...d.php?t=222059 I just hate catching people when they lie... Might want to also look at: http://www.automotiveforums.com/vbul...d.php?t=137254 or http://www.automotiveforums.com/vbul...d.php?t=513964 As for this thread, Mike, your problem is a changed gearing caused by decreased tire size, right? You can get around that by talking to a reputable chip programmer and getting your limiter changed in your PCM ... the 6.5TD run real good up to about 4000 rpm with enough boost. Above that you need stronger springs on the valve train to stop the 'float'. Sounds like you have a cool truck, Mike... Hope this helps!
1994 2500 Silverado 6.5L Turbo Diesel
Heath Remote PMD, Turbomaster, Max-e-Torq 2.0 3"/4" SS Exhaust Real Trucks Don't have Spark Plugs
#17 |
LOL You beat me to the link.
Bad info and overpriced products that are extremely good at draining you wallet and nothing else. LOL |
#18 |
Member ID: 32466
from Jim - this is being handled at the moment. Please stop the attack posts on each other while I sort this out. Thanks.
#19 |
Please read the post about this one - Jim
#20 | |
Absolutely. I'll go back to finding what I came here for. Jim
| Advertisements |
| Thread Tools | |
| Display Modes | |
