Old 06-25-2006, 09:21 AM   #21
iridektm
Ma G-Status B Triplen
iridektm's Avatar
Member ID: 38397
Re: OBS diesel's
woudlnt that be a little much for that engine?
SOLD - 98' Chevrolet Silverado 2500 4x4. Full Throttle 9.5 lift. 10" Rear Springs.
1-1/2" Block. 1-1/2" Crank. 38x14.5 Toyo M/T. 4.88 Yukons.
This one better be right..
Old 06-25-2006, 10:27 AM   #22
Firestrike87
Premium Member #51
Didn't know what to type.
Firestrike87's Avatar
Member ID: 44112
Re: OBS diesel's
Thats a sweet lookin truck there man. I'd go for it if everything looks good.
1997 Z71 | 6" BDS | 35x12.5 M/T Baja Claws | 15X10 Classic II | Flowmaster 40 Series | 5.7 Vortec | 4L60E | 3:73
Check out my Cardomain site for pics - http://www.cardomain.com/ride/1833894
Old 06-25-2006, 10:38 AM   #23
iridektm
iridektm's Avatar
Member ID: 38397
Re: OBS diesel's
Yeah im leaving in about an hour to check it out. Gotta get the price down ALOT!
Does DC make a kit for 8 luggers? (and does the diesel have anythign to do with a lift not being able to fit)
Old 06-25-2006, 12:05 PM   #24
Pete-FWA
Member ID: 34163
Re: OBS diesel's
Originally Posted by iridektm
When the 6.5 turbo came on the scene, all of sudden, cooling issues arose. The original cooling system was not adequate enough to handle a turbo powered upsized engine. These issues would continue on until 97.
I've also been told that the cooling system can be upgraded to the '97 setup. I corresponded with SS Diesel Supply last year about a 1994 6.5 Turbo. This is part of Walt's reply to my questions:
"Hey Pete,
In stock form you have 430ft/lbs @1800 rpm. I'd like to see a gas engine even come close!
For more hp and torque, there are many things you can do relatively inexpensively. First start with a 4" exhaust and induction kit. Diesels need to breathe. Add a set of gauges, egt and boost. Then a power chip for an extra 80hp and 160 ft/lbs of torque.
Being a '94 [I was learning about the older 6.5 at this point], if the cooling system hasn't yet been upgraded, do so immediately. Our ssd-004 cooling system upgrade will take care of that. For towing, I highly recommend our fan upgrade also.
Walt,
SSDiesel Supply
2307 Military Rd
Tonawanda, NY 14150
ph 716-692-7700
www.ssdieselsupply.com"
The information on their site is good and they do have some products and services for sale.
Old 06-25-2006, 12:11 PM   #25
Pete-FWA
Member ID: 34163
Re: OBS diesel's
A 2500 can be lifted, but most will tell you that any lift will change the handling characteristics and reduce weight capacity.
I've seen plenty of lifted 3500 DRW's, but the people who lift those seem to be doing it for the look. I know no one with a lifted DRW who hauls major weight...usually it's just taking a speed boat to the lake to play. That's a load many half tons could pull.
Old 06-25-2006, 01:12 PM   #26
iridektm
iridektm's Avatar
Member ID: 38397
Re: OBS diesel's
I know you can lift 2500 lol. Just wondering if DC made a 8 lug kit. and if the diesel engine changed how the lift would be installed.
thanks for that site and email! the one im lookin at is a 97, so the cooling system shoudl be alrgith, right?
How much do those upgrades cost yuou reckon.
Old 06-25-2006, 02:37 PM   #27
iridektm
iridektm's Avatar
Member ID: 38397
Re: OBS diesel's
Just looked at the truck. Sat real pretty. It knocked alot though. It is probably because it hasnt been cranked forever and it was cold. It was definitly a horse trailer towing truck.
Dad cranked it, said he heard and saw enough. We left.
I guess I gotta trust him on it...............ah I NEED a truck or Im going to go crazy. I have been looking for 6 months now.
Old 06-25-2006, 02:55 PM   #28
bmdean
Member ID: 39716
Re: OBS diesel's
go to ssdiesel supply and you can buy a cooling upgrade it, it includes a duramax fam and hd fan clutch and a dual thermostat crossover i think. all problems that arose with the 6.5L can be corrected. another common problem on the 6.5L's was the injector pump, because it had an electronic box mounted on top if it under the intake manifold (i'm pretty sure that's where it is?) so a lot of heat builds up and burns that electronic box. you can buy a replacement along with a heatsink that moves it to the top of the intake manifold where it is much cooler.
edit: sorry didn't see that other post about ssdiesel supply
Brandon
new truck
1999 Chevy Silverado LS 1500 Z71
old truck
1992 GMC Sierra 2500 LD 350/700r4
(mods "HOPEFULLY" soon to come)
Old 06-25-2006, 06:34 PM   #29
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: OBS diesel's
You guys need to quit telling him to upgrade the cooling system....the truck he is looking at is a 97 - it already has the upgrade from the factory....
EDIT - Do not mount the PMD on the intake as mentioned in the above post - go to Heath diesel and get the relocating kit that will allow you to mount the PMD OUT OF THE ENGINE BAY and either under the bumper or on the skid plate (underside facing engine)....
1/4 Mile ET
16.722 @ 80.701 MPH
Old 06-25-2006, 06:50 PM   #30
iridektm
iridektm's Avatar
Member ID: 38397
Re: OBS diesel's
ill keep that in mind, but
Old 06-25-2006, 07:18 PM   #31
Pete-FWA
Member ID: 34163
Re: OBS diesel's
Wasn't sure how much weight you were going to pull...nah, no change in the lift installation between gas and diesel.
The cooling upgrade kit they sell is $335 and with the Duramax fan kit included, it's $499.
Sorry the one you saw today wasn't the right truck...you'll find one eventually.
Old 06-25-2006, 07:32 PM   #32
red suburban
red suburban's Avatar
Member ID: 46297
Re: OBS diesel's
sry about the long post earlier, just answering some of the power/benefits options.
diesels are known to last for well over 200k miles if taken care of, worked on one today (oil change) that had a 6.5L with over 356k miles on the odometer, ran great.
is your dad familiar with diesels? alot of times when you start one thats been sitting for a while it will make a knocking sound (expecially when its cold) until you get some new fuel in there and the engine has warmed up.
Old 06-25-2006, 07:54 PM   #33
Larry B
Larry B's Avatar
Member ID: 9701
Re: OBS diesel's
I've got a 97 and if it hasn't run in a week it will make a lot of noise until it warms up. My only problems have been replacing the boost solenoid and the injector pump twice. Check with a dealer about the warranty on the pumps. The first one was paid for by GMC but the second I got stuck paying for $$$
Old 06-25-2006, 08:26 PM   #34
bmdean
Member ID: 39716
Re: OBS diesel's
chrisk1500, i haven't heard of that kit. sounds like a good place to put it. i've heard of heath, just not that relocating kit. i'm not sure how it mounts, just looking at the pics on their site that's what it looks like.
Brandon
new truck
old truck
Old 06-25-2006, 08:46 PM   #35
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: OBS diesel's
Heath's kit is made to mount on the skid plate...comes with PMD, extension harness and heat sink....
Personally I just extended my own wires and mounted my PMD on a heatsink....heatsink is mounted behind the bumper so that airflow coming in through the holes in the bumper sweep across the fins....works great....PMD never gets hot....
1/4 Mile ET
16.722 @ 80.701 MPH
Old 06-25-2006, 09:19 PM   #36
restoguy
Member ID: 36655
Re: OBS diesel's
Lotta mis-information flying around here about the GM diesels....But a lot of good stuff too! Bottom line is, if you think you want a diesel, inform yourself about what you're buying before you plunk down a pile of hard earned clams. Check out some of the good websites out there. I'm a member at www.thedieselpage.com and it's the best $20yr I spend.(I own a'94 6.5L, remember) There other good ones too. Also, there are good sites for Navistar(Ford) and Cummins(Dodge)
When my roommate was looking at a '96 diesel back in 1999 I told him not to buy it 'cause it wouldn't work out well for his needs. But I didn't know anything about them at that time, I just thought I did. After he got it, I learned a lot about them and then went and bought my own! He traded is truck off and says to this day that he should have kept it. That's after trailering it to the shop(1.5hrs away!)for IP work, 4 times in 6 weeks one summer!
If it seems like I can't make up my mind about these things(they break a lot--I bought one and love it), I'm sorry. I just hate reputation that these trucks have and I would hate to see someone get into one just because 'Diesel' is the new big thing and they can't afford a newer one. They will probably won't get what they expect and will just bad mouth it for the rest of eternity. But if you know what you're getting then your not suprised and life is a lot better.
By the way, if anyone has 6.5L questions, I'll be happy to help. I've got plenty of experience!
Old 06-25-2006, 10:14 PM   #37
iridektm
iridektm's Avatar
Member ID: 38397
Re: OBS diesel's
Does anyone have a sound clip of their 6.5 that works great, when it is cold or something. My dad knows about diesels, just not as much as gas. He is more familiar with the New Duramax though. He compared how this truck sounded, compared to a new duramax and a 02 powerstroke.
So a sound clip or something, that would be awesome!
Thanks!
Old 06-25-2006, 10:51 PM   #38
dozerboy
dozerboy's Avatar
Status: Online
Member ID: 25211
Re: OBS diesel's
They sound like most any diesel when its cold they knock and smoke.
Old 06-26-2006, 08:31 AM   #39
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: OBS diesel's
Lots of politics on that particular site.....better off to go to www.dieselplace.com - it has just as much info as the page and its free....
1/4 Mile ET
16.722 @ 80.701 MPH
Old 06-26-2006, 11:14 AM   #40
iridektm
iridektm's Avatar
Member ID: 38397
Re: OBS diesel's
i go to dieselplace an dtry to learn there to.
