Old 07-05-2006, 12:28 AM   #41
Boosted
Boosted's Avatar
Member ID: 24959
Re: OBS diesel's
Well to the guy talking about lifting a diesel truck is just for show I think not. My truck is a '93 3500 that is completely stock except for 8.5" lift, SAS swap, and 39.5" tires. I just got towing a 1978 25' Cabin Cruiser. Had no problem going anywhere. Towed it like it wasn't there. The only thing I did notice is that it got a little hot(210-225 range) and that it would slow down up steep upgrades. But that is because of the gears.
My upgrades are going to be as follows:
Gauges(#1 priority in a diesel. Gota know what ur truck is doing)
Exhaust
Intake
Cooling upgrade w/ dual 2500cfm electric fans
Dual Tranny Coolers
Dual Oil Coolers
Aluminum Cored radiator
Boost Controller
The truck towes anything and everything fine and spits plenty of black smoke. My truck has 182,000 on it and doesn't skip a beat. Has been well taken care of and I just perform regular maintence.
About the only thing I would trade my truck for would be a truck in the 4500 series range.
'83 F250: 460/C6/Dana 24, 24" Lift, 53" Michelins on 20" Mickey Thompsons, Rockwells w/ Disc Brakes and Hydro-Assist
Old 07-07-2006, 08:03 PM   #42
BIGRED Z
Rapper (J-DOGG),Mechanic
BIGRED Z's Avatar
Member ID: 50781
Re: OBS diesel's
7.4 is a TBI 454 and a 7.4 454 Vortec
98 Chevy ECSB Z71 3dr euros,tails,33 Toyo Open Country M/T Firestone Airbags for towing Superchips,Dynomax duals,Airraid Throttle Spacer,Comp Camshaft FIPK
93 Chevy RCSB Stepside K&N aircharger 20 A/R Rims Sold
Old 07-07-2006, 08:36 PM   #43
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: OBS diesel's
Electric fans on a 6.5 is asking for an overheat condition...
They can't move anywhere near the same CFM as a properly working clutch fan....
Better off buying the D-max fan and clutch and just bolting it on...
Just my 2 cents....
1/4 Mile ET
16.722 @ 80.701 MPH
Old 07-16-2006, 03:11 AM   #44
chevy_man
Status:
Posts: n/a
Re: OBS diesel's
If you buy the right electric fans they will be more efficient than a clutched fan. They will move just as much air through the radiator with no problems.
Old 07-18-2006, 11:01 AM   #45
red suburban
red suburban's Avatar
Member ID: 46297
Re: OBS diesel's
true, less of a drag on your motor. but, you have to make sure that they can move the same cfm or more.
Old 08-28-2006, 05:43 AM   #46
ladukeja
04yzinger
ladukeja's Avatar
Member ID: 15637
Re: OBS diesel's
I bought my diesel late last year. It has been running like a champ, and I haven't had to replace much, besides a coolant temp sensor and an oil pressure switch, and regular oil changes. Both were inexpensive items. My diesel runs a 17 second quarter, and thats a stock engine with a 4" exhaust. I have big plans for it in the performance dept. I have have had it for 16,000 miles, since 162,000. It knocks like a metallic knock sound, but it is probably just normal diesel knock. It is very dependable for a DD, but in the winter idk what I will do. Probably a tank heater and plug the engine block heater in.
1994 Chevrolet C1500 L56 6.5L Turbo Diesel, Long box, std cab, 4L80E, true-trac 3.90, 186,000 miles, 4" straight piped exhaust, modified air intake, EAlloy 217's & 275/55R18(forsale), black ss steelies & 31x10.50R15's for winter
1940 Buick Roadmaster
-Jeff
Old 08-28-2006, 01:27 PM   #47
mr_goodwrench_0
Member ID: 26321
Re: OBS diesel's
It will start just fine. Just make sure you have good batteries, and a good glowplug system. Maybe look at getting a set of Quick Heat glow plugs. Pluging it in certainly helps, but you won't even need that if you run Synthetic oil in it.
Bill
'99 2500 Suburban'07 Kawasaki Mean Streak'97 Chevy XCSB 4X4 350 Vortec 1500 '94 GMC Crew Cab 4X4 Diesel 3500
Old 08-28-2006, 09:59 PM   #48
ladukeja
04yzinger
ladukeja's Avatar
Member ID: 15637
Re: OBS diesel's
mrgoodwrench, what oil weight do you recommend for the 6.5 in the winter?
-Jeff
Old 08-28-2006, 11:30 PM   #49
mr_goodwrench_0
Member ID: 26321
Re: OBS diesel's
I have always run synthetic 15-40 year round with no problems.
Bill
Old 08-29-2006, 09:02 AM   #50
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: OBS diesel's
I run 10W 30 in the winter (as per the owner's manual)....we can easily hit -40 degrees celsius in the dead of winter....keep it plugged in at all times!
1/4 Mile ET
16.722 @ 80.701 MPH
Old 08-29-2006, 09:44 AM   #51
mr_goodwrench_0
Member ID: 26321
Re: OBS diesel's
When I pulled the engine out for a rebuild on my old truck I installed 2 block heaters. One on each side. That was the BEST cold weather mod EVER! I had to park that truck for a week at a time in -40 weather. I'd get off work, plug it in, and it'd flash up no problem in about 20 min. I also had a small battery charger that was always pluged in and kept the batteries topped up with a 2A trickle charge.
Bill
Old 08-29-2006, 03:31 PM   #52
ladukeja
04yzinger
ladukeja's Avatar
Member ID: 15637
Re: OBS diesel's
Thanks for the tips. I might try and switch to synthetic oils, I always run 15W-40 (dino/sythetic blend), usually the delvac 1300 type i think. My Grandpa ran Chevron 15W-40 in his trucks after talking to the truckers about what they used. I was thinking of a tank heater too, to help the fuel not jell, for the cold starts. I might need to change my glow plugs before the winter to help with the cold starts.
-Jeff
Old 08-29-2006, 08:52 PM   #53
dozerboy
dozerboy's Avatar
Member ID: 25211
Re: OBS diesel's
Delvac is good I think for the price and quality Delo is the best. I had heard good things about Shell Rotella T syn. for winter starts.
Old 08-29-2006, 09:54 PM   #54
dozerboy
dozerboy's Avatar
Member ID: 25211
Re: OBS diesel's
Old 08-29-2006, 10:30 PM   #55
mr_goodwrench_0
Member ID: 26321
Re: OBS diesel's
There is a factory fuel heater in the filter housing. I'm not against adding extra stuff to make cold starts easier, just FYI. New glowplugs would certainly help if the condition of yours is poor or unknown.
Bill
Old 09-03-2006, 09:41 PM   #56
maclean
Member ID: 14441
Re: OBS diesel's
Does anyone know of an aftermarket Glow Plug for a 6.5 that might be better or longer lasting?
MacLean
2002 Chevrolet Silverado ccsb HD Duramax
Old 09-04-2006, 11:31 AM   #57
K5Fury
K5Fury's Avatar
Member ID: 42906
Re: OBS diesel's
Do a search for Heath Diesel or SS Diesel Supply.
Old 09-14-2007, 03:20 PM   #58
GMac4x4
Hog Wild!
GMac4x4's Avatar
Member ID: 46662
Re: OBS diesel's
Originally Posted by K5Fury
Did Detroit diesel make the 6.2 and 6.5 for GM or did Izusu?
im pretty sure it was izusu but i might be wrong
'97 6.5TD 2500HD Ext.CabLB 4L80tranny w/4.10 14B FF,3"pipes,K&N intake,16x8 Eagle Alloys,305/75 BFG AT's
'84 SCSB SB350,Cam,Headers,Edelbrock IM/4barrel,beefedTH350/NP208TC,D60 Front/Detroit TruTrac,14BoltFF w/ Detroit Locker,4.56's,Rancho 6"/3"BL,dual straight pipes,ProComp 15x12,38/15.50 TSLs
Old 09-14-2007, 10:32 PM   #59
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: OBS diesel's
Wrong.....
1/4 Mile ET
16.722 @ 80.701 MPH
