Old 06-30-2006, 12:22 AM   #1
1toncrew
Member ID: 37611
fuel leak on 6.5 TD
hey all, noticed I was leasking fuel. I believe i pinpointed the location. Looking from the passenger side towards the rear of intake manifold I could see something dripping. One of the lines leads to there. Anyway How do i render this problem? dont know much about this engine.
Fuel was dripping off the starter and bellhousing. I followed the lines and they were mostly dry considering how much fuel was leaking ( a drop a second) The only thing I can think of Is the leak on the manifold. thanks for any help
Old 06-30-2006, 08:16 AM   #2
mr_goodwrench_0
Member ID: 26321
Re: fuel leak on 6.5 TD
That is where the fuel filter is. Maybe the top is not tight, or maybe one of the lines is damaged or loose. Buy a new filter and replace it. While you are back there, look for any problems.
The filter housing is bolted to the back of the intake manifold. It has a round ring that screws on and holds the filter in place.
HTH,
Bill
'99 2500 Suburban'07 Kawasaki Mean Streak'97 Chevy XCSB 4X4 350 Vortec 1500 '94 GMC Crew Cab 4X4 Diesel 3500
Old 06-30-2006, 10:26 AM   #3
1toncrew
Member ID: 37611
cool I didnt notice a filter back there, actually didnt know it was there K gonna try that thanks goodwrench
Old 06-30-2006, 10:35 AM   #4
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Who does your maintenance?..... .....
1/4 Mile ET
16.722 @ 80.701 MPH
Old 06-30-2006, 01:07 PM   #5
1toncrew
Member ID: 37611
Well in my defense, I just got the truck. But I do need to find out what i need to do as regular maintenance.
Old 06-30-2006, 01:42 PM   #6
mr_goodwrench_0
Member ID: 26321
http://dieselplace.com/forum/forumdisplay.php?f=21
Bill
Old 06-30-2006, 02:52 PM   #7
Jim
Smoke Eater
Jim's Avatar
Member ID: 1
Originally Posted by mr_goodwrench_0
so how is that helpful? You didn't link to a specific thread just to the 6.5 forum over there.
Old 06-30-2006, 03:03 PM   #8
mr_goodwrench_0
Member ID: 26321
Sorry, I wasn't trying to give a specific thread, just point him in the right direction. There is an incredible amount of info over there. Sometimes it is better to search for info like that rather than have it handed to you.
Chris and I are both members over there!
Bill
Old 06-30-2006, 03:51 PM   #9
Jim
Smoke Eater
Jim's Avatar
Member ID: 1
that's understandable, sometimes though it just makes it hard to get things going here and build a good knowledge base when you keep getting sent somewhere else
Old 12-27-2006, 08:55 PM   #10
PLANTMANS
Member ID: 59049
Their Is A Metric O- Ring Under Bottom Of Fuel Filter(manger)housing, I Had To Replace Mine. I Had Fuel On Top Of Manifold I Had To Take Rags And Dry Up Fuel To Determine The Fuel Leak Source.also Had A Lot Of Gunk In Bottom Of Filter Housing.should Clean Out If Removing Filter Housing.
Plantman 3500 Hd 6.5 Td. 120,000 Miles
