Old 07-05-2006, 09:04 PM   #1
OBS 6.2L
Member ID: 50647
New Needs Help First Diesel
HI all i just bought this 1982 6.2L diesel for $300.00 was this a good buy? the trouble i have is that it smokes like a train (white smoke) is this bad the guy said that the motor and pumps was rebulit but the truck was sitting for 7 yrs only ran to push cars around can anyone help me plese i tried the dieselplace but they want $20.00 to join and i dont have the money the truck has 158,000 miles on it any help would be great thanks
Old 07-05-2006, 10:24 PM   #2
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: New Needs Help First Diesel
It is free to join at www.dieselplace.com ......better try again...
www.thedieselpage.com charges its members a fee - don't go there.....
As for your problem - glow plugs check out ok?....you might just need to get some new fuel in it - run some heavy shots of power service through it to clean up the fuel system....
1/4 Mile ET
16.722 @ 80.701 MPH
Old 07-06-2006, 03:38 PM   #3
red suburban
red suburban's Avatar
Member ID: 46297
if its white smoke its water in your system. replace your fuel filter, get new fuel, and ALOT OF FUEL SYSTEM CLEANER!! going by what you stated about it sitting most of the time there will be alot of water in the fuel tank. you will need to drain your water seperator (if equipped on the 6.2, i'm not certain). if it has one it should be by your fuel filter. water is attracted to diesel fuel for some odd reason (thats y the "water in fuel" light is in the dash.
ps... great buy, if you can get the motor runnin great then you spent less than what the motor alone is worth.
Old 07-06-2006, 03:53 PM   #4
Mental Health
BANG YOUR HEAD!!!!!!
Mental Health's Avatar
Member ID: 49663
I agree that is a very good buy pictures would be nice too.
Old 07-06-2006, 10:05 PM   #5
OBS 6.2L
Member ID: 50647
I tried that bot nouthing came out I put some power service in it to day it clered it up some but it stil smokes prety bad fiday iam going to try the outher tank that is empty to see if fresh fuel in it and one more bottle of power service in. I cant post pic's wet due to the fact that I live in N.J and I cnat reg it yet. I also checked for bubbles in rad and there was none and also for blow by took of oil cap while it was running and there was also no smoke and no oil in the air breather . is this a good sing?? I will keep you posted on what happens thanks
Old 07-06-2006, 10:41 PM   #6
red suburban
Member ID: 46297
did u drain your water seperator and change your fuel filter? good that you dont have any blowby, means your rings are doin just fine.
Old 07-07-2006, 02:34 PM   #7
OBS 6.2L
Member ID: 50647
today I put some fresh fule in the outher tank and after about 15 min it stops smoking I think it was the old fule then I tried the outher tank and then it started again i think they may have used off road diesel fule thanks for the help
Old 07-07-2006, 05:24 PM   #8
chrisk1500
chrisk1500's Avatar
Member ID: 28947
FYI - off road fuel/farm fuel does not smoke any more than pump diesel....
1/4 Mile ET
16.722 @ 80.701 MPH
