Old 09-06-2006, 05:02 PM   #21
red suburban
red suburban's Avatar
Member ID: 46297
Re: Mpg?
the 6.5 is not an amazing tower you are correct, older diesels cant even compare with new ones without some major upgrades. earlier you stated that the 6.5 has around 185 hp and 400 ft/lbs of torque, not uncommon changes with a diesel. most gas engines (350 is another story) have more hp than torque, but the difference is not that great. diesels are not hp engines, the old 6.2 had around 150 hp, but about 310ish ft/lbs of torque.
when it comes to gassers the 350 is quite honestly one of the best. decent fuel mileage, reliable, and alot of power in a small package. making it a vortec was the best thing chevy ever did to that motor (idiots for getting rid of it). but, just because the older diesels took off like an old granny doesnt mean they couldnt tow. usually a diesel will take off the same with/without a medium load. biggest problem with the 6.5 powerwise is the stock exhaust, and the older models had smaller turbo's as well.
Old 09-11-2006, 06:53 PM   #22
grey86carryall
Used to have a 65
Member ID: 54270
Re: Mpg?
the thing to remember about torque numbers is the rpm involved the lower the rpm the less horsepower, a 10,000 foot pounds at 1 rpm engine has half as much horsepower as a 2 foot pounds engine at 10000 rpm.
I have some friends who haul calves in big horse trailers for a living. they have 2 ford double cab one ton duallys. one has a diesel, one a v10. they say (and they are old with no axes to grind ) that the v10 pulls away from the diesel going up the hills. both are 02s 0r 03s I think when loaded both rigs run around 24,000 lbs. they say 10 mpg on the v10 12 mpg on the diesel v10 has 260000 miles no major repairs and the diesel 180000 miles two injector pumps and the dealer told them that they need a f550 to haul that kind of load, that that is two much weight for the f350 diesel. I have hauled calves in them and both are slow up the hills but zip along on the level ground, pretty comfy trucks but I prefer chevys.
Old 09-11-2006, 09:08 PM   #23
red suburban
Member ID: 46297
Re: Mpg?
10mpg towing that weight with a v10 is amazing to say the least. a friend of mine has a 2002 (i think) f250 with the triton v10, gets 11mpg city unloaded. got about 6-8mpg highway with his car-hauler and a 79 ford f100 loaded on it.
Old 09-12-2006, 12:21 AM   #24
Troyc20
poopsocked
Troyc20's Avatar
Member ID: 46811
Re: Mpg?
Sorry to butt in but i did'nt even know that the 6.5TD exsisted or a GM TD for that matter. What i want to know would the old 6.2 be a good daily? They suck on the "go fast" area right? does this 6.5TD have any balls(outside of towing)?
Originally Posted by Boarsheadburban
I'll bet you don't use condoms either, your'e a gambling man. right?
Old 09-12-2006, 08:18 AM   #25
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: Mpg?
The 6.5 in a truck with 3.73's can get into the very high 16's but usually mid 17's in the 1/4....
It can go faster though....ask Bill Heath about his 500 HP 6.5.....
1/4 Mile ET
16.722 @ 80.701 MPH
Old 09-12-2006, 02:03 PM   #26
red suburban
Member ID: 46297
Re: Mpg?
the old 6.2 will get you around fine with the best fuel economy (unless you want to drop in a cummins 4bt). your right, it is very slow, equivelant to the 305 with acceleration. however, you can upgrade it with a turbo to make it move alot better. turbo setups can either be bought from banks or make your own using a gm8 turbo and exhuast manifold from a 6.5L.
6.5 was introduced in 93. better power than a 6.2 but the early years, before 97, had cooling issues but that is easy to resolve. for acceleration in stock form a 6.5 is about the same as a tbi 350, but with more torque.
Old 09-12-2006, 06:19 PM   #27
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: Mpg?
pretty sure they were available in 92.....
1/4 Mile ET
16.722 @ 80.701 MPH
Old 09-12-2006, 06:58 PM   #28
Troyc20
poopsocked
Troyc20's Avatar
Member ID: 46811
Re: Mpg?
My buddy has a 87 TBI 350 and its stock but has plenty of giddyup, throws you into the bench evrytime. I think I might have to find a 6.5TD now.
Old 09-12-2006, 10:10 PM   #29
red suburban
Member ID: 46297
Re: Mpg?
your right, but i believe it was towards the end of the 92 production year.
Old 09-18-2006, 06:37 PM   #30
tinsoldier
I am THAT guy.
tinsoldier's Avatar
Member ID: 54714
Re: Mpg?
Originally Posted by cl1986
allright i give up.....but i still dont believe it....id have to see the two stock trucks pulling the load to believe it....
im not so sure on the staying in overdrive either....the 98 6.5 td we had would downshift on steeper hills on interstate with no load at all.......
i know I am new here. I just bought a 95 suburban 4 weeks ago with a 6.5l turbo diesel in it. I towed a 5200LB mini van on a car dolly threw the PA mountains, never left 70 mph the whole 5 hr trip in OD at about 2k (downshifted on some of the big hills). I have driven a Chevy Van with a gas and it was a dog. :) Not bad but just shifted a lot on hills.
I have had my truck up to 100mph on the flat in Ohio (it was scary and won't happen again (GPS verified)).
I am also getting an average 15 MPG bone stock highway/city combo driving. I want more but don't know how to do it yet.
Best truck I have ever owned!
Old 09-18-2006, 11:04 PM   #31
chrisk1500
chrisk1500's Avatar
Member ID: 28947
Re: Mpg?
Funny this thread got pulled back up.....
I just drove my wife's 00 Jimmy through some hills out here and with the cruise @ 80 MPH the truck had to downshift into D on some of the bigger hills to maintain speed.....on the same hills with my truck at the same speed my TCC does not even disengage while in OD and the cruise set.....
I realize I am comparing a v6 vortec to a v8 turbo diesel but the vortec has around the same HP as a 305 TBI iirc.....
just some food for thought....
1/4 Mile ET
16.722 @ 80.701 MPH
Old 09-19-2006, 10:33 AM   #32
cl1986
cl1986's Avatar
Member ID: 20115
Re: Mpg?
edit
Old 09-19-2006, 10:35 AM   #33
cl1986
cl1986's Avatar
Member ID: 20115
Re: Mpg?
other food for thought....
the gas engine is SUPPOSED to downshift....its capable or running 5-6k rpm....why not use it??
when my 98 downshifted it usually was around 3-3800 rpm and rarely if ever downshifted to run 5k....my bosses 04 on the other hand will downshift and run 5k all the time just pulling some snowmobiles.....
believe it or not my 2000 pound jeep will pull harder than our S300 bobcat that weighs about 8000 pounds......wind is a primary factor.....so sometimes the load doesnt matter.....esp if going over 65 MPH.....damn SD wind!!! Jeep does have a 8" lift and 38" tires so it sticks well above the cab of the truck
I can drive straight into the wind no problem.....its the side winds that kills me....esp on I-90
Old 09-22-2006, 11:27 AM   #34
topcop38
Member ID: 55314
Re: Mpg?
i'm new here. i'm looking at buying an '07 silverado soon. it will be an x-cab 4x4 loaded. i might consider the diesel in the 2500 but i need more info. i frequently pull a 3500lb trailer and will occasionally pull a 6000lb trailer. this can be done with the 1500 5.3 with no problem.
what i want is fuel mileage. i have always owned trucks, some fords and a few dodges, but i insist on a GM this time, mainly because of mileage and past experiences. my current truck is a 96 GMC sierra 1500 4x4 x-cab with 138,000 on the 5.7. it pulls fine and runs great. i've never owned a diesel before. in my research i've been told that for mileage you need the allison 6-spd.
what kind of mileage should i expect with the diesel? i would be willing to install the reprogrammer for improvements but thats about the extent of modifications.
based on my pulling requirements should i forget about the diesel and go with the 5.3?
also, on another thread i read that they are coming out with a new baby diesel in '07.
any truth to that? any info?
Old 09-22-2006, 01:35 PM   #35
cl1986
cl1986's Avatar
Member ID: 20115
Re: Mpg?
it really depends on what ur doing.... the 5.3 will be similar to the 5.7... but remember you get more torque at lower rpm and more power at lower rpm on the 5.7 (ie 3800) compared to the 5.3 (ie 5200)
If you want to pull at 60 mph or faster....diesel is about the only way to go...
If its just a trip here and there and only a few hours at a time you can get by with the gasser...
One of my excavating contractors has his skidload and trailer hooked to his duramax at all times and the truck is only for work and gets 10-12 MPG driving from lot to lot (may be 5 up to 35 miles per trip)
I usually got about 8-10 MPG pulling with my 5.7 vortec same...5-35 miles at a time and sometimes interstate at 65 MPH...
ON the other hand my 03 duramax will go just about as fast pulling a skidloader as a gasser can go empty.....with edge chip that is...
Alot of pulling = duramax
Ocassional pulling = gasser
My 5 speed allison does extremly well loaded or unloaded but 6 would be better.....not too much difference im assuming....
Old 09-22-2006, 07:35 PM   #36
red suburban
Member ID: 46297
Re: Mpg?
if your going to be towing and want a gasser get the 6.0 or get a 98 or older with the 5.7 if you are gonna be towing at 60+mph. like cl1986 stated, the 5.3 reaches its power at around 6k rpms, at long periods of that rpm your engine is gonna drink fuel like an alchoholic at a beer festival. the 6.0 is basicly the best gas replacement for the 5.7, similar fuel economy and its torque band is similar to that of the 5.7, so much better than the 5.3 for towing.
i know chevy is coming out with a smaller diesel, but i've heard it might not be till 2010, but i dunno for certain.
Old 09-22-2006, 09:37 PM   #37
topcop38
Member ID: 55314
Re: Mpg?
my dad had an 01 1500 with a 5.3 that he said got around 14-15mpg around town. last year he bought a 2500 with a 6.0 and says he only gets about 11mpg. this will be my everyday driver so fuel mileage is essential.
an older one with the 5.7 is out of the question. i have that now and its a great truck but i will be buying a brand new one.
i will be towing about 15-20 times per year. most of it will be about a 10 mile trip with an occasional longer journey.
i'm leaning towards the 5.3 because of mileage but if i can get 14-15mpg around town with the 6.0 then i'll go with that.
i like the looks of the 2500 better than the 1500.
i don't want to buy either and regret it 2 months later.
if i go with the gasser then i will install a re-programmer and air intake to gain some power and MPG. i think the 5.3 with these upgrades would be okay.
my dads 5.3 wouldn't pull his 8000lb boat too well thats the reason for him going to the 6.0.
he says it pulls fine but he can't afford to keep gas in it.
what kind of mileage are you guys getting with the 5.3 and 6.0?
Old 09-23-2006, 11:17 AM   #38
Zick
Member ID: 15311
Re: Mpg?
When my '03 was stock w/ the 5.3, I was averaging around 16-16.5. Now with the LQ9 6.0 built w/ 11.5CR and my own tuning, I'm getting about 15mpg average. It will still get around 18-20 on the hwy too. But with the higher stall convertor and big cam it doesn't fair too well when towing but then again I didn't build it to tow.
That's why I'm now selling it to buy an '07 DMax.
Born on 11/20/06: '07 Classic GMC 2500HD DuraMax Edge Evo
SOLD-03' Silverado ECSB 6.0 LQ9, Patriot LS6 heads, TR230, 31lb inj, TB stall, vette servo, Corsa, HP Tuners
SOLD-99' Silverado ECSB 5.3
Old 09-23-2006, 12:04 PM   #39
topcop38
Member ID: 55314
Re: Mpg?
i'm not overly concerned with mileage while towing as about 90% of my driving will be around town with no load. mileage under load is important to me, just not as important as regular driving.
if i can get 14-15mpg around town unloaded with a 6.0 then i would go that route.
do you think that with the air intake and programmer on the 6.0 i could get that with a 2500 x-cab 4x4 auto?
Old 09-23-2006, 12:19 PM   #40
Zick
Member ID: 15311
Re: Mpg?
I doubt the air intake will do much, but with a custom tune(not a hand held programmer) I think you should be able to pull off 14-15. As long as your not running 4.10 gears or large tires, as I think that will hurt you the most.
